What do these codes mean?
Old Feb 22, 2006 | 09:31 PM
A BirdMan Converted's Avatar
A BirdMan Converted
Default What do these codes mean?
96 LT4
My car sounded like Chitty Chitty Bang Bang. Expect NASCAR LOUD!!!!
DTC P0300
DTC P1171
Thanks.
Old Feb 22, 2006 | 10:22 PM
FD2BLK's Avatar
FD2BLK
0300 is a muti cyl miss fire (Distributor, coil, CPS etc...)
1171 Oxygen Sensor System too Lean Fault Banks A & B
Use this
http://www.jpurnell.com/RR/LucasEFI/...scan_codes.htm
Old Feb 22, 2006 | 10:37 PM
LT4BUD's Avatar
LT4BUD
Originally Posted by A BirdMan Converted
96 LT4
DTC P0300
DTC P1171
Thanks.
Diagnostic for the DTC P1171....from 6-655 of GM Manual
Check fuel pressure......If low then
1.Plugged fuel filter
2)Damaged fuel pressure line
3)Restricted clogged fuel pump stainer
A good starting point...
Old Feb 22, 2006 | 11:26 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Doing my best CFI imitation
It means You need to get the Factory Service Manual
Old Feb 23, 2006 | 03:53 AM
skateparkdave's Avatar
skateparkdave
You forgot....
RACE ON!!
CFI's da man.
Old Feb 23, 2006 | 08:10 AM
runner140*'s Avatar
runner140*
Damn good imitation. I like it.
Old Feb 23, 2006 | 08:48 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
CFI has no concern with being 'politically correct' but he is AND right on.
RACE ON!!
RACE ON!!
RACE ON!!
Old Feb 24, 2006 | 09:49 PM
A BirdMan Converted
that could also be due to running low on gas right?
l was, as they say in NASCAR, Runnin' on fumes....
I coasted a half mile to the nearest station to fill er up.
-Kevin
To What do these codes mean?
