Build recommendations?
Old Feb 23, 2006 | 06:19 PM
silver86's Avatar
silver86
Default Build recommendations?
Some things have changed for my build in my 86 cast iron (don't they always?). Since I just bought MrNuke's blower kit, I'm going to have to dig in a little further into the top end than I had originally planned.
Here's how it stands:
Right now, stock cast iron 86 with SLP stainless muff's and Dynomax y-pipe...sounds good....but could be more fun to drive.
Parts on hand/to be added:
Carroll supercharger kit including Paxton SN-60 blower pushing 9 psi with water/meth injection
Ported plenum
TPIS Big Mouth
Edelbrock runners
52mm Throttle Body
Erson cam 220/231@.050 .499/.512 corrected 1.6 lift 112 centerline
1.6 flat tappet rockers
Hedman 1 5/8" ceramic coated LT headers
AFPR
Gutted cat (oops!)
Hypertech air foil
Ganatelli 8mm wires
MSD coil
And, of course, I'll need a custom tune now.
I have a set of 3.56 gears to install, but I'm debating on these now since I don't believe I'll be able to hook this thing up with the blower....this is just my weekend cruising car and while I want it to be wickedly fast, it's not going to be a track racer. Thoughts?
I was also curious about head gaskets. The car has 132,000 miles on it, and I wasn't going to change them before I bought the blower. Now I feel this is a necessity. But I'm curious about type and thickness. I'm considering copper gaskets @ .093 compressed thickness just to keep the CR in check with the blower. But I'm not sure here....And of course now I'll be doing the 3-angle valve job and new seals to boot.
Thanks for everyone's previous input and parts/sales...this place is awesome!!!!
Old Feb 23, 2006 | 07:59 PM
MrNuke's Avatar
MrNuke
You're damn right you'll have traction problems if you gun it below 40mph..
I was runnig Dragradials (Nittos) on the street which gave me a LOT more traction than normal tires, and I still could smoke them up like crazy...
Old Feb 24, 2006 | 03:00 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
? Are you going to cut the heads?
Are the rings in the block still holding good compression.
What is the compression now?
What did your leak down show?
Old Feb 24, 2006 | 08:02 AM
silver86's Avatar
silver86
Hmmm....maybe I need to step up to ZR-1 size wheels and tires and leave the 2.59's in the rear, huh?
I haven't tested the CR yet...I've only driven the car 400 miles since I got it around Christmas...and I haven't experienced any problems to make me rush and do the test...but it is on my list to do. Factory compression for the 86 with cast irons is 9.0:1.
I've considered doing some mild porting on the heads, especially since I discovered a machine shop 2 miles from the house! But I haven't made up my mind here. I probably should enlarge the valves as well, just for fun, but we'll see what happens.
I'll know more about the bottom end when I begin the tear down...it seems solid, more solid than the 85 I once had...strong pulling, willing to rev. So, I'll keep my fingers crossed...
Old Feb 24, 2006 | 09:10 AM
mn_vette's Avatar
mn_vette
I think 3.56's will be too much gear for the car, I thought the consensous was 3.33's is where you need to be with a TPI and not so high rpm's
I would save the money on the heads and make sure that you have the fuel system up to snuff first. Definately some new injectors, probably a new fuel pump as well, filter for sure. Get away from the FMU if you are planning on using one.
I think 9.0:1 with 9 psi should be just fine with meth injection. I would save touching the heads until you need to rebuild the motor.....and you know you are going to want more power after a while too. I would take baby steps, and make sure you do each one right.
Old Feb 24, 2006 | 04:06 PM
AKS Racing's Avatar
AKS Racing
You did not mention whether 4+3 or auto. If it is auto with a long tube intake, then 3.33 is a great gear, but I found 3.45s to be too much with a blower, as you will need to shift to OD at the end of the 1/4 mile, which kills autos. If std, then start thinking about a clutch/PP, as it will eat the stock one without much issue.
Welcome to the addiction, there is no cure (except a wife w/ the checkbook).
I can help you with some on your list (intake parts, roller rockers, TB, etc.)
Aaron
Old Feb 24, 2006 | 09:32 PM
silver86's Avatar
silver86
Sorry...it is an auto. I'll make a few runs at Moroso down here and see where my rpm's end up in the traps.
I actually have/or on the way all of the parts that I listed. Now its just finding the time. Your right about the wife thing...I have my stuff sent to my office address!
AKS..I'm actually from Houston. I still have alot of family there and get back at least once or twice a year.
To Build recommendations?
