L 98 Oil Pan
Old Feb 24, 2006 | 10:35 AM
GreyHairedTopGun's Avatar
GreyHairedTopGun
Default L 98 Oil Pan
I have an 89 (L98 engine) and the question is, are the oil pans for other Chevy 350's from that year the same height as they are for Vettes?
Old Feb 24, 2006 | 11:34 AM
RWDsmoke's Avatar
RWDsmoke
I used a 96 vortec truck motor and pan in my 86. Works just fine.
Old Feb 24, 2006 | 08:23 PM
JMixon's Avatar
JMixon
If you do use a different pan, check the oil pump pickup -vs- sump orientation. You may (probably will) need a different pickup.
Old Feb 24, 2006 | 09:44 PM
redrose's Avatar
redrose
all the gm smallblock pans that i have seen (hundreds of em-really) are the same height....lower portion of some runs futher forward for greater capacity ...internal baffles vary...i've got a '67 five quart pan on the '75 block in my '86 vette and if fits fine altho the oil cooler piping is a tight fit.
aftermarket pans come in multiple depths,kick-outs,etc
check pick-up height if you change pans.
do NOT use a chromed pan--heat disipation is poor
Old Feb 24, 2006 | 10:39 PM
GreyHairedTopGun
Default thanks
Thanks for the reply. At one time I knew about chroming, but have long since fogotten.
To L 98 Oil Pan
