Keep the EGR? EGR bypass?
Old Feb 24, 2006 | 12:27 PM
C4CBF's Avatar
C4CBF
Default Keep the EGR? EGR bypass?
86 L98
I want to put on some Hooker 2154's and I know they don't have a EGR bung. Should I have one welded on and keep the EGR system? I'd rather take it off but I don't want to have to deal with the ECM throwing codes.
A buddy of mine (Ford guy) said he bypassed his on his Stang. Is there any way to do it with a L98? I read Vader's site and he clipped the wire coming off the EGR sensor and it didn't throw codes for his specific car. Just wanted to see what everyones opinion was of the EGR.
Thx
Old Feb 24, 2006 | 12:35 PM
vader86's Avatar
vader86
All i did was yank it off and put a blocking plate on the manifold. I didnt do anything else.
no codes
Old Feb 24, 2006 | 01:34 PM
C4CBF's Avatar
C4CBF
no codes
Nice.
Old Feb 24, 2006 | 02:11 PM
Red Tornado's Avatar
Red Tornado
don't disable EGR without having yor chip re-programmed to ignore the EGR function. doing nothing but bypassing EGR will leave you more prone to detonation, and you most definitely don't want that. during EGR conditions (part throttle, under 80% TPS which is where you spend most of your life), the ECM dials in extra timing, it does so since cooler combustion temps allow for increased timing. higher combustion temps with increasing timing = more prone to detonation.
why disable EGR in the first place? folks that do this have me lost. it doesn't do squat in hurting performance by leaving it in as it should be.
i would get the hooker 2149's with the AIR and EGR hookups.
Old Feb 24, 2006 | 07:44 PM
C4CBF's Avatar
C4CBF
I see your point, I want to remove the AIR at least to make way for a SC one day. But I think I can have a EGR bung welded to the 2154's and keep it on there. Definitely want to stay away from detenation
Old Feb 24, 2006 | 09:56 PM
Aardwolf's Avatar
Aardwolf
"why disable EGR in the first place? folks that do this have me lost. it doesn't do squat in hurting performance by leaving it in as it should be"
Nasty carbon build up all over the intake.
Old Feb 25, 2006 | 09:23 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I removed mine just because it was ugly and made valve cover removal hell. I have yet to throw a code or have any driving issues, but i do run a cooler thermostat.
Old Feb 25, 2006 | 12:37 PM
bogus's Avatar
bogus
A cooler t-stat won't help you one bit.
The t-stat is not a temperature regulator, it's a temperature setter... it will set the minimum temp, but once it gets to a temp, it won't go down.
Leave the EGR... it actually HELPS performance and helps emissions. I call that a win-win.
Old Feb 25, 2006 | 12:44 PM
cv67's Avatar
cv67
St. Jude Donor '05
I believe the EGR helps cool the combustion chamber, which helps thwart detonation. Keeping it is a plus in my book. Had problems with mine to, just replace all of it next time the plenum is off and forget about it. Parts are fairly cheap.
Old Feb 25, 2006 | 12:46 PM
vader86's Avatar
vader86
theres a page on my website that discusses EGR function
Old Feb 25, 2006 | 03:00 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Also, once you install a cam with some overlap, the EGR's function becomes redundant anyway, which is why the LT4 didn't even require one from the factory to meet emissions. Besides, it's just one more worthless piece of crap in the way under the hood. I'll run high flow cats but the AIR and EGR are history.
To Keep the EGR? EGR bypass?
