Smoothing out manifold?
Old Feb 25, 2006 | 12:02 AM
nelson84's Avatar
nelson84
Default Smoothing out manifold?
What tool would be best for smoothing out the little bumps and burr's on a SDPC TPI intake manifold inside the air passage ways?
Old Feb 25, 2006 | 12:05 AM
steve1ph2's Avatar
steve1ph2
iv used a dremel. bought it from home depot.
Old Feb 25, 2006 | 12:16 AM
stubbs's Avatar
stubbs
Summit sells a little porting kit that has all different bits in a wide array of shapes and sizes. I think its like 12 dollars, good buy.
steve1ph2's Avatar
steve1ph2
cheaper than the dremel
Old Feb 25, 2006 | 12:19 AM
stubbs's Avatar
stubbs
You still need the Dremmel, these are just bits for the Dremmel. And its 19.50 not 12 dollars I found out, heres a link
http://store.summitracing.com/defaul....asp&x=48&y=11
second from the bottom
Old Feb 25, 2006 | 12:34 AM
steve1ph2's Avatar
steve1ph2
i tell ya when i first bought my sawzall it was king. then i bought a dremel. but like both you always forget about them. the carb conversion im doing now has seen the dremel and the sawzall. it makes the process so much eaiser.
Old Feb 25, 2006 | 12:38 AM
stubbs's Avatar
stubbs
Wait till you try a Plasma Cutter, oh baby. We also used to have a giant Band Saw, we used it to cut the front off of a 3rd gen Trans Am to pull the motor one time. It took about 10-12 seconds, it was awesome! I love tools of destruction!
Old Feb 25, 2006 | 12:45 AM
BlackC6LS3's Avatar
BlackC6LS3
dremel on ebay with bits for like $20 shipped, a huge carbide bit and go to town
Old Feb 25, 2006 | 12:57 AM
steve1ph2's Avatar
steve1ph2
lol, dude i could take down a 4 story building with my sawzall then resharpen the blades with my dremel.
Old Feb 25, 2006 | 09:57 AM
Aardwolf's Avatar
Aardwolf
I am doing clean up on a manifold now. I got for about $4 a drum sanding wheel for my drill and the sand paper rolls. It's working very well. I am using an extension for the drill to get farther into the manifold. That's the only thing that sucks. Putting the drum bit into the extension results in slop. I have been wrapping some teflon tape around the bit so it doesn't fall out. It needs to get replaced about as often as the sand paper though so it's not so bad. Use 80 grit to take down all the casting flash, seam lines, etc. Then polish it up with a finer grit. It was easy to do the manifold and runners, the plenum really needs hogging out though! For that I got a carbide burr and am going to use my neighbors shop with a huge air compressor. A drill will not spin the burr fast enough FYI.
Old Feb 25, 2006 | 11:43 AM
rick lambert's Avatar
rick lambert
Sawsall-my wife heres that around my place-well you get the idea anyway, I've done alot of porting in the past-the best
advice I can give you is Dremmel-BUT, don't go cheapo on it, get
a good one. Obviously aluminum is alot easier than the old cast I
used to do-but still get a good one, and some carbide cutting tools
for it.
Old Feb 25, 2006 | 12:27 PM
cv67's Avatar
cv67
St. Jude Donor '05
w/Lambert, buying a quality tool costs more up front but makes the job much easier, especially on a TPI base. When using an extension, it really wears on the bearings. I use a Mutabo electric that is adjustable from just under 1000 pms to around 10.Dont have access to a proper compressor to use my other die grinder... Carbide bits its on the lowest setting, cartridge rolls and flap wheels around 2000. On thirdgen.org there is plenty of home porting going on, a few guys who are doing some nice work and freely share tips. Hard to come by good info, the guys that know how to do it are usually secretive about it.
IMO a drill wont get you the result you need.
To Smoothing out manifold?
