GS 50mm offset = ? backspacing
Old Feb 25, 2006 | 09:33 AM
Hairmetal_still_rox!'s Avatar
Default GS 50mm offset = ? backspacing
At the risk of being redundant I will ask anyway. I am currently looking at a set of ARE Hopster wheels for my 90 vette. 17x9.5 front and 17x11 rear. ARE does not list offset in the custom sizes ( 17x11 being one of them ) and lists backspacing of 8". Is this equal to the GS 50mm offset or more or less. IE I dont want them sticking out past the fenderwells ( well a 1/4 inch is ok ) Is the GS offset 7.5 inchs of backspacing? 7.75, 8, 8.25 etc. Anyone know exactly? Thanks in advance
BTW: I have my Torque Thrust IIs ( all 4 are 17x9.5 ) listed in the C4 for sale section with like new tires. All mint.
Old Feb 25, 2006 | 12:04 PM
bogus's Avatar
bogus
take your existing TT3s.
Lay a straight edge over the outer rim edge, on the inside of the wheel. Then drop a ruler onto the hub and measure. THAT'S backspacing.
Offset is a little harder to measure... that is measured from the exact vertical center of the wheel... and the negative is if the offset is to the outside and positive is if the offset is to the inside.
Old Feb 25, 2006 | 12:16 PM
Thanks for the info although I indeed already knew how to measure backspacing. That is why I was trying to relate it to the 50mm offset that the GS calls out as. Do you know what the backspacing is on the gs 50mm offset wheels are? Thanks for your comments
Old Feb 25, 2006 | 12:39 PM
vader86's Avatar
vader86
backspacing on GS rims should be 7 7/8"
Old Feb 25, 2006 | 01:22 PM
Thanks vader, thats great news as the AREs will fit inside the fenderwheels with no issues. 315 35 17 here I come !!!!!!!!!!
Old Feb 25, 2006 | 02:25 PM
bogus's Avatar
bogus
I didn't know that... and I didn't have the number, so, much like teaching a man to fish....
Old Feb 25, 2006 | 02:36 PM
No worries Bogus, thanks for taking the time to answer just th e same
To GS 50mm offset = ? backspacing
