power ant.
Old Feb 25, 2006 | 06:04 PM
dad90's Avatar
dad90
Default power ant.
hi im new to this corvette stuff got 1985 need to replace power ant. how do i get to it thanks john
Old Feb 25, 2006 | 06:53 PM
87vette's Avatar
87vette
Take off the drivers side rear wheel. Remove the inner wheel well. And you will see the antenna bolted in place with a bracket. disconnect that. You will also have to follow the line going into the rear comparment in the car and disconnect that also. Should be under the carpet. Not hard at all.
Old Feb 25, 2006 | 07:26 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
sounds about right. This was one of my first projects on my 91. If I remember correctly I installed an aftermarket antenna for about $50. It also helps if you have skinny arms.
Old Feb 25, 2006 | 10:21 PM
Sam Lam's Avatar
Sam Lam
John: Are you replacing the entire unit or just the ribbon/mast assembly? Either way, you should remove the power unit. The ribbon/mast is not expensive and this solves most problems. I can scan this page from my 89 Helms manual and email to you if you wish.
SAM
Old Feb 26, 2006 | 12:16 PM
dad90's Avatar
dad90
SAM
thank guys
Old Feb 26, 2006 | 07:43 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/agent86/Power%20Antenna.pdf
Old Feb 26, 2006 | 08:30 PM
Craig's Polo '93's Avatar
Craig's Polo '93
Default Antenna
My antenna goes up fine but won't go down all the way.
The last small segment stays up.
Is there a simple cure for this or do I have to
buy/install new mast?
Where do I buy a kit or mast.
I have a '93 vert.
Thanks,
Craig
Old Feb 26, 2006 | 08:45 PM
AGENT 86's Avatar
AGENT 86
I have a '93 vert.
Thanks,
Craig
GM has a replacement mast. Nylon ribbon with finial end of antenna
Old Feb 27, 2006 | 12:11 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Try just replacing the mast first. If your motor runs when you turn your radio on and off, you know the motor is still good. If if you have a broken section of the old mast ribbon lodged inside your motor, you'll have to remove the entire unit for servicing.
To power ant.
