Wal mart synth. oil?
i have read more than once--don't use diesel oil in autos. that being said, synthetics may not apply. if you know enlighten me please.
frog.
I use diesel oils (Velo and Rotella) in my old truck (no cats), but stay with gasoline type oils in the rest of my fleet.
Larry
code5coupe
Its alway good to hear everyone elses take on certain things becouse
you can put them togther and come up with a diffrent maybe even better one in the end. Or learn things you will never even dream about(example diesel oil in gaspowered auto) thats new to me.
Google is your friend.
Larry
code5coupe
Larry
code5coupe
-- these folks know a lot more about oil than I ever will, or want to
breakdown, they have to be, a diesel engine ignites the fuel by heat
of compression not spark plugs, so there is tremendous heat. A diesel
tractor trailer gets used hard and needs that protection. I would not
run a paraffin based oil in my car especially if you take it out for short
runs and don't get it heated up good. Paraffin is wax, and wax is liquid
when its hot but solid when it's not. That why you can get crud build up
in your engine. I'd stick with a good synthetic imo.
For those that can't download that, here is a quote from the wear test:
"The ASTM D-4172 4-Ball Wear Test is a good measure of the existence and robustness of an oil's additive
chemistry. It is used to determine an oil’s ability to minimize wear in case of metal-to-metal contact. The test
consists of a steel ball that sits atop three identical ***** that have been placed in a triangular pattern and restrained
from moving. All four ***** are immersed in the test oil, which is heated and maintained at a constant
temperature. The upper ball is then rotated and forced onto the lower three ***** with a load measured in
kilogram-force (kgf). After a one-hour period of constant load, speed and temperature, the lower three ***** are
inspected at the point of contact. Any wear will appear as a single scar on each of the lower *****. The diameter
of the scar is measured on each of the lower ***** and the results are reported as the average of the three scars,
expressed in millimeters. The lower the average scar diameter, the better the wear protection of the oil. In this
case, the load, speed and temperature used for the test were 40 kg, 1800 RPMs and 150° C respectively.
Interestingly, the SAE 40 oils with the highest and lowest levels of zinc, Maxima Maxum 4 at 2,464 ppm and
Pennzoil Motorcycle at 1,010 ppm, had identical results. Royal Purple, with an average level of zinc (1,474 ppm)
had the largest wear scar (nearly 55% larger than the next closest wear scar size). Zinc levels for those oils performing the best, AMSOIL MCF, Mobil 1 MX4T, Motul 300V Sport and Torco T-4SR ranged from 1,061 to 1,762 ppm.
The SAE 50 group showed a similar trend. Golden Spectro 4, with the highest zinc level (2,162 ppm), performed
less than average in the 4-Ball Wear Test, while the Motul 300 V Competition, with the lowest zinc level (1,048
ppm), tied with AMSOIL MCV and Torco T 4SR with the best test results.
The results strongly suggest that simply having high levels of zinc is not sufficient to effectively minimize wear."
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
