LT4 extreme chain
Old Feb 26, 2006 | 09:59 AM
tjwong's Avatar
tjwong
Default LT4 extreme chain
Just a quick update to ease some worries. I had a customer and forum members engine apart last week. I had installed a Extreme timing set into this engine some time ago and shipped the engine to So Cal for installation. It came up to my shop for tuning and because of other issues I removed the engine to check the internals out. In the process I inspected the LT4 timing set and found absolutely no signs of abnormal wear on the waterpump drive gear. Of course this engine is near new, but has a few hundred miles on it and several 6500 RPM dyno passes. By the way this engine made over 580 RWHP in 5th gear which peaked at 6000 and held it nearly flat to the test RPM end point of 6500 RPM !
Old Feb 26, 2006 | 01:00 PM
larryfs's Avatar
larryfs
so your point is ????
Old Feb 26, 2006 | 01:02 PM
Mo_Bandy's Avatar
Mo_Bandy
Way to go Tom!
Everything is sorted out on it now?
Mo
Old Feb 26, 2006 | 02:36 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I'm wondering if some of the problems with these might be due to the front oil gallery plugs being replaced with ones that don't have the holes in them. Also, there was the question of some folks, possibly not using the pump drive gear that comes w/ the ED set. What are your thoughts on this, Tom?
Old Feb 26, 2006 | 07:14 PM
Mo_Bandy's Avatar
Mo_Bandy
Larryfs,
The point was there was some discussions some time back where the waterpump drive gear was eating up the cam gear on the extreme gear set.
Tom was kind enough to share a update...
Mo
Old Feb 26, 2006 | 07:57 PM
larryfs's Avatar
larryfs
is there a link to the issues being discussed?
Old Feb 26, 2006 | 09:33 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
There were a few but I think this was the one that got everyone wondering:
http://forums.corvetteforum.com/show...m_id=48&arch=1
Old Feb 27, 2006 | 07:01 AM
FD2BLK's Avatar
FD2BLK
I just read somthing interesting in another thread. Mo Brandy stated that if you put a SBC double roller chain in an LT4 you need to add a .10 shim to compinsate for the reluctor ring being removed. Is it possibble that the LT4 ED set is .10 thiner then the LT1 set? If so perhaps this is the source of the problem, just a thought that could be chacked rather quick with a digital caliper if someone had both timing sets.
Old Feb 27, 2006 | 09:01 AM
sothpaw2's Avatar
sothpaw2
Originally Posted by tjwong
In the process I inspected the LT4 timing set and found absolutely no signs of abnormal wear on the waterpump drive gear. !
Mine didn't have any wear on the waterpump drive gear either--the Cam sprocket/gear is what was completely eaten away. GM makes the small waterpump gear very hard and the cam sprocket/gear very soft.
How was the water pump itself? Mine hardly turns. I could NOT turn it by hand the other day at all grabbing the splined shaft. Taking the screws out and touching the impeller--now I can turn it. But it's tight-tight-tight.
The metal shards in the pressed in waterpump gear bearing also have locked it up--hard to turn it and it's not smooth.
So I stand by my Conclusion--bad water pump bearing by *** of Canada. At high rpm (5000) it wore the ED cam sproket enough to send shard into the bearing of the WP gear drive and then both accelerated the wear & shard production.
This explains why it is a rare issue--only LT4's or ED sets will be affected and only if you happen to get a bad waterpump (a new one--probably have let quality slip as with the Clutch slave Cylinder's and Opti's). And the bad waterpump in mine didn't show itself for 15,000 mi and there were plenty of drag passes and 4 track days in those miles, along with 3 high rpm dyno passes. The bearing just didn't last, it was ok for a while.
Old Feb 27, 2006 | 11:41 AM
sothpaw2's Avatar
sothpaw2
Just to clear this up--
2 Folks on this forum, myself and Michael (MSR), had the correct LT1 oil plug with the hole and we both had the same problem with the Cam sprocket wearing itself to death. Mine was a stock, untouched shortblock.
Also, I can confirm (because I have the pieces now) that my car certainly had the ED wp gear on it--the entire ED set was installed as called for. This was also the case with MSR if I recall.
Old Feb 27, 2006 | 02:39 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Good point. I have a 96 set up, with the reluctor ring, and I know for a fact if that reluctor ring is not pushed up correctly against the crank gear you can break things in there. I broke an Opti because of this, more than likley because my reluctor ring was out a little. So, it is possible that if the crank gear isnt put in right, or as far as it needs to be to be aligned, I could see extra strain down there being transferred up to the wp gear eventually.
Old Feb 27, 2006 | 04:54 PM
tjwong's Avatar
tjwong
Originally Posted by Mo_Bandy
Way to go Tom!
Mo
It is almost done. I had the engine out and had the pistons coated with a thermal barrier, anti-friciton coating on the skirts and a oil shedding coating on the undersides of all the pistons. I also ground another cam with a wider LSA to improve the engine vacuum situation with the brakes. The overall cam specs are still the same. I also replaced the Felpro 1074 headgaskets with a set of MLS style gaskets. I had headgasket that started to seep coolant so this should fix that problem. As an additional note and to clarify what I mentioned earlier there was no wear on the cam sprockets waterpump drive as well.
Old Feb 28, 2006 | 01:23 AM
Mo_Bandy's Avatar
Mo_Bandy
Fd2blk,
I responded to this in the other thread as well but for those here. I clarified that the crank gear is the same depth, the difference is in the crank hub, this is only on the 96's I beleive as the 95's did not have the reluctor wheel on them..
I would agree as posted previously that it is probably more a function of a waterpump seize than that of the timing set... my personal opinion...
Mo
To LT4 extreme chain
