Running Rich
Old Feb 26, 2006 | 11:14 AM
DG'sVette's Avatar
DG'sVette
Default Running Rich
95 LT1 75000 miles
Car seems to be running rich. Any ideas on where to start trouble shooting this condition?
Recent parts replaced:
Fuel Filter
Air Filter
Spark Plugs
Spark Plug Wires
PCV Valve
Various Vac. Hoses
Cleaned Throttle Body
Old Feb 26, 2006 | 11:26 AM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
What is telling you that the car is running rich? Were the old plugs carbon fouled? Pull one or two of the new plugs - are they fouled? Was it running rich before you replaced all those parts?
Why did you replace various vacuum hoses? A vacuum leak will make a car run rich, so definitely make sure that all of the hoses are routed properly and the connections are tight.
Did you remove the throttle body to clean it? Any codes?
(Sorry for all the questions - the more info, the better )
Old Feb 26, 2006 | 11:38 AM
DG'sVette's Avatar
DG'sVette
I'm not a mechanic. Going by neighbors word. He seems to pretty knowledgeable.
When looking at the exhaust tips there seems to be allot of carbon built up. This is the sign I was going by. I'm I wrong? Is this a sign of a rich condition?
The plugs looked fine when I replaced them. The only thing I notice was they were gapped large than the manual called for. All the hoses were replaced because they appeared to be rotted.
Old Feb 26, 2006 | 12:02 PM
byebyeL98's Avatar
byebyeL98
Carbon build up on the exhaust tips can indicate a rich condition, but the plugs are a much better indicator of current performance. If they look fine, I would believe that the car is not currently running rich.
Old Feb 26, 2006 | 01:00 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Everyone has some carbon at the tips.The best way to diagnose it would be to get a laptop and Datamaster and get a scan done and post it.It is a great diagnostic aid and will tell you more than you can imagine.
Old Feb 26, 2006 | 06:00 PM
bmalec's Avatar
bmalec
Also, when you replaced the spark plugs, were all the plugs consistently colored?
Ben
Old Feb 26, 2006 | 06:13 PM
MikeC4's Avatar
MikeC4
first thing to do is see if your ECM has stored any error codes. Easy to read on a '95. You can short pin4 and pin12 on your ALDL connector and read error codes where your fuel gauge normally displays:
http://www.obd1.com/
and here's a link to desypher error codes:
http://www.troublecodes.net/GM/
Old Feb 26, 2006 | 06:33 PM
DG'sVette's Avatar
DG'sVette
No codes - All plugs looked the same
Thanks for the info guys.
I think I'm just going to consider the car good. No codes, I don't smell any gas so, with all the info I recived today I'm happy.
Another satified customer.
Old Feb 26, 2006 | 09:01 PM
MikeC4's Avatar
MikeC4
heh heh...for a Vette, running good is good enough....
Old Feb 27, 2006 | 10:31 PM
parafrog's Avatar
parafrog
From: Tucson, AZ. L98-85 AUTO COUPE: 120k MILES: daily driver. SOUND OFF IF YOU'VE BEEN THERE. Ex-Jumpin' Junky-82nd Airborne-2/505 PIR: 1st ID-1/16th Inf: Recon Marine Retread. GOD BLESS GRUNTS.
check out plug reading on this site:
http://www.4secondsflat.com/Spark_plug_reading.html
frog.
Old Feb 27, 2006 | 10:44 PM
Jerris's Avatar
Jerris
No codes stored, leave it alone.
Jerris
Old Feb 27, 2006 | 11:13 PM
MikeC4's Avatar
MikeC4
frog.
nice URL frog....thanx for sharin'
Old Feb 28, 2006 | 12:33 PM
byebyeL98's Avatar
byebyeL98
- Great link - thank you!!!
To Running Rich
