Turn signal flasher I believe is behind the center info bezel right above the stereo. The emergency flasher is under the passenger kickpanel right above the ecm.
On a 89 the Turn signal flasher is located under the passenger side of the dash near the fuse block. Drop the hush panel, lay on your back look up and you should see it.
The Hazard flasher is located behind the center area of the dash.
You are probably correct. It's been awhile since I did mine. My fuse box however is on the side of the passenger dash by the door. I had to pull down my ECM to get to the turn signal flasher.
