U Joint strap bolt ??
Old Mar 1, 2006 | 10:46 AM
rufneck's Avatar
rufneck
Default U Joint strap bolt ??
What is the torque when reinstalling the strap bolts on the half shaft u joints?? I don't want to strip them out. I know I need a helms manual. Thanks
Old Mar 5, 2006 | 04:47 PM
Duntov85's Avatar
Duntov85
use a little 8mm wrench. Unless you are king kong, I doubt you'll tighten them too tight. You want them tight. Make sure there is blue threadlock on them.
Old Mar 5, 2006 | 09:13 PM
redrose's Avatar
redrose
shop manual sez 26 ft lb (35 N.m)
and the blue loctite
To U Joint strap bolt ??
