O2 Sensor thread size
Old Mar 5, 2006 | 08:16 PM
CF6873's Avatar
CF6873
Default O2 Sensor thread size
Today while removing the the 02 sensors on my 94, one of them left some material in the threads of the pipe. I soaked these things with PB Blaster for a week and this one still would not come out gracefully. I'm going to need a tap to clean up the threads. Does anyone know what the thread size is for this. Thanks
Old Mar 5, 2006 | 08:45 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
18x1.5 metric. Maybe you could run an old sensor back in and dislodge the pieces? A tap that size will be pricy. Maybe an icepick would allow you to pick the pieces out?
Old Mar 5, 2006 | 09:46 PM
redrose's Avatar
redrose
you can get a ''spark plug'' thread chaser at most auto parts stores, most are double-ended 14mm/18mm....never try to remove o2 sensors when they're cold (guess you already have figured that out)
Old Mar 5, 2006 | 09:56 PM
CF6873's Avatar
CF6873
Actually after soaking it and it still was not budging I heated the area with a torch and still got the grief. I have tried picking but the threads look a little shabby and another sensor will not screw in. I think I can borrow a tap. Thanks for the size info.
To O2 Sensor thread size
