Code 34??????????
Old Aug 12, 2001 | 12:15 PM
RMWICK1's Avatar
RMWICK1
Default Code 34??????????
Engine running ruff when I start and almost dies. Try to give her some gas in Neutral and she tries to dies. In about 30 seconds she smooths out and drives fine. Got a Code 34. Can anyone help??????????? :smash: :confused:
Old Aug 12, 2001 | 03:35 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Code 34?????????? (RMWICK1)
I'm away from my Lit but I believe #34 is the MAF. In that case check the burn-off and MAF power relays as well as clean connections and inspect the MAF sensor wire.
