When Lowering the rear only, Alignment nessc.
Old Mar 3, 2006 | 09:58 AM
bdaly84's Avatar
bdaly84
Default When Lowering the rear only, Alignment nessc.
If I lower just the rear on an 84 z51, do I need to get an alignment?
Second, do I have to remove the rear wheels, I have heard both ways, I really dont want to remove the wheels.
Old Mar 3, 2006 | 10:04 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
yes, you will need to get it aligned. You don't have to remove the wheel but it makes like easier.
Hairmetal_still_rox!'s Avatar
Remove the wheels to get an alignment or replace the bolts?
Old Mar 3, 2006 | 10:05 AM
Totally agreed, the bolts can easily be replaced without removing the wheels. Alignment would be recommended.
Old Mar 3, 2006 | 10:43 AM
sami85L98's Avatar
sami85L98
When i lowered mine rear only, i did not do alignment but may be needed but i have not seen any difference in driving without alingment,
Old Mar 3, 2006 | 12:41 PM
bdaly84's Avatar
bdaly84
Thanks for the info.
To Sami85L98...yours looks awesome, do you have Z51? Did you do the front or did it lower when you drop the rear? I have heard Z51 cars sit higher?
Old Mar 3, 2006 | 01:08 PM
tequilaboy's Avatar
tequilaboy
Lowering should increase negative camber a bit at the rear, and will most likely increase the toe in.
Check the toe with a stick or something that you can run under the car, and turn in the tie rods evenly as required.
Old Mar 3, 2006 | 04:57 PM
redrose's Avatar
redrose
ez way to check toe
cut two pieces of 1 x 8 ( really 3/4 x 7-1/2) board same lenght as tire diameter...lay the boards long side on ground , leaning squarely against tire at about 45*...now you can easily measure both ends, as long as you are reasonably gentle the boards won't move
Old Mar 18, 2006 | 11:40 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
If you lower it, how much camber increase per inch? Guestimate?
Old Mar 18, 2006 | 11:49 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
If you're only lowering an inch or so, probably nothing to worry about. You'll gain a tad of negative camber but that's a good thing on these cars. Chalk line your tires and get an accurate before and after measurement of toe, but that's not likely to change enough to matter either. Still, I'd be more concerned with any possible changes there than with the camber.
Old Mar 18, 2006 | 11:58 PM
Sinister87's Avatar
Sinister87
I was told, that anytime you mess with the suspension on these cars you should always get a 4wheel alignment afterwards.
Old Mar 19, 2006 | 01:36 AM
Corvette Kid
It depends on what you're doing and if you know what you're doing. It's also possible to do a precise four wheel alignment at home, with no special equipment, if you want to take the time.
Old Mar 19, 2006 | 01:51 AM
Sinister87's Avatar
Sinister87
Yeah thanks for the input KID but I wasn't referring to wheather or not I could do it, I was trying to be helpfull and pass along the info.
Old Mar 19, 2006 | 06:20 AM
rodj's Avatar
rodj
"I have heard Z51 cars sit higher?"
Other way round.My factory stock Z51 is so low at the front can hardly get fingers between guard and wheel whereas most stock Vettes have a couple of inches.
Old Mar 19, 2006 | 06:28 PM
froggy47's Avatar
froggy47
I'd love to do my own alignment as I autox and am alway tweaking stuff & like to try different aligns.
Do you have a link to a do it yourself align. place?
TIA
Old Mar 19, 2006 | 06:38 PM
Corvette Kid
TIA
I used to have a link for that saved but I think it's one of many that AOL decided I didn't need anymore. Anyhow, I have a caster and camber gauge which makes it even easier. They're not that much. If you have one, it's real easy to put things back where they were before you took them apart. The toe is just a matter of accurate measuring.
Old Mar 19, 2006 | 07:59 PM
froggy47's Avatar
froggy47
How do you get under to make the adjustments? Without the align ramp/pit it's hard, no?
To When Lowering the rear only, Alignment nessc.
