AC DELCO Plug help!! # please
Old Oct 27, 2025 | 07:48 AM
the blur's Avatar
the blur
Originally Posted by IHBD
You have the part number wrong.
R43TS is the standard duty taper seat plug used for many, many decades. It still exists on RockAuto for $1.66 each.
There is also a CR43TS. Same plug, but the leading "C" is a "commercial" application with a larger diameter center electrode. Everything else is the same as the R43TS. Rock Auto has CR43TS for the same $1.66 each. I've used both with no discernable difference, I change copper core plugs at about 35,000 mile intervals..
In the late 80's, there was a plug R43CTS. & R45CTS. Not a leading C. But where I have it in the part #.
Old Oct 27, 2025 | 10:42 AM
IHBD's Avatar
IHBD
Pro Mechanic
There may have been. If there was, the trailing "C" was copper core. I thought all "regular" delco plugs are copper core now. Maybe they are, and that is why the suffix C was dropped? Doesn't matter to me, the plug numbers I cited work for me. They will for you too. You're welcome.
