AC DELCO Plug help!! # please
Old Mar 4, 2006 | 05:21 PM
rick lambert's Avatar
rick lambert
Default AC DELCO Plug help!! # please
Time for that tune up. Went to Auto zone, watched them search their computer and came home with AC Delco # 41-629 plugs. Anyone use these? the reason I ask is last time I ended up with some Autolite 26s.
The difference is astronomical in appearance!! The ACs have a compression ring-the tapered type-the Autolites don't-and the ACs are
about 1/2 inch longer on the thread/electrode length than the Autolites, WTH, I certainly don't want the wrong plug in there-any numbers on your ACs??? thanks in advance
Old Mar 4, 2006 | 05:40 PM
aminnich's Avatar
aminnich
And your driving a what? Let's assume it is a corvette (Yugo's are in a diffferent forum). Ok, year? engine? stock? Vettes come with ac/delco fas as I know. Isn't autolite Ford?
Old Mar 4, 2006 | 06:01 PM
rick lambert
Dang-I'm sorry! 87 vette, 350 TPI, I deserved that
Old Mar 4, 2006 | 06:46 PM
rick lambert
Wat-cmon, somebody has a plug # right
aminnich's Avatar
aminnich
S'ok. We all have oxygen deprived moments. Mine is LT1, so can't help with the correct ac/delco number, but whatever it is I would never run
Autolite, not even in my Mustang and certainly not in my vette.
Old Mar 4, 2006 | 06:49 PM
MikeC4's Avatar
MikeC4
ditch the Autolites and stick with OEM AC plugs. Your owners manual should tell you the exact type of AC plug to use....
Old Mar 4, 2006 | 07:15 PM
rick lambert
Owners manual-AC type FR3CLS, Haynes AC R43CTS, FSM-I can't find a recomendation or plug type! I know I like the ACs-Autozone, Nappa and Schucks all say AC 41-629----is this what you're using?
Old Mar 4, 2006 | 09:10 PM
Morley's Avatar
Morley
The FR3CLS are a flat seat plug with a washer, used in aluminum heads.
The R43CTS is a taper seat plug used in iron heads.
The 41-629 is the A/C replacement for FR3LS
Old Mar 5, 2006 | 07:53 AM
rick lambert
Right as usual Morley-thanks. Went to ACDelcos site and verified. Funny, thought guys here would jump all over it with plug numbers. :o
last time I needed plugs and new wires I didn't have time to do it,
and dreaded the knuckle busters-so I took it to a shop I trusted, and told them I wanted plugs and wires put in. She ran great and has always started without hesitation-great performance. So, this time I'm doing it and go oh sh#t, Autolites. Went and got the ACs and then noticed the difference-amazing-the ACs are approx. 3/4 from washer to
electrode-the Autolites are approx. 1/2 inch. Why they feel the need
to change numbers is mind boggling. You were right about the old number to-according to the owners manual. Funny I couldn't seem to find it in the FSM, maybe I didn't look hard enough. Thanks again
Old Mar 5, 2006 | 09:57 AM
Morley's Avatar
Morley
I just went through the plug madness myself. Trickflow says to use FR3LS plugs...so off to the parts store we go...I need 8 FR3LS plugs. first they want to know what car they are for. Doesn't matter, I need 8 FR3LS...For what car? The bimbo at the counter would not relent so I told her; 85 Camaro 305 F. Oh, you need R43TS. NO! I need 8 FR3LS. So she hands me off to one of the guys there. He looks them up, no listing but the number does cross ref to Autolites, NGK and Champion, but no cross to another AC plug number. So I had to find the new Delco number for myself and go back to play the "what car?" game all over again.
Old Mar 5, 2006 | 10:11 AM
rick lambert
So-did you end up getting the 41-629s? I never even thought about looking in the owners manual-have to say the general did a great job on that. If he would have made RR plugs a little easier it would have been nice. Funny thing is the #8 is always the easiest for me on the passenger side. I wonder exactly what the difference if any between the FR3CLS and the 41-629 other than number there is?
Old Mar 5, 2006 | 10:54 AM
cv67's Avatar
cv67
St. Jude Donor '05
You gotta tell the parts guy what you need these days. When I first bought the 89 I went to get plugs and the counter guy insisted the plugs for the ZR1 will fit ("5.7, same thing" )Not even close!
Old Mar 5, 2006 | 11:14 AM
rick lambert
So, what did you end up with cuisinartvette? of course if you went with
platinums they will be another number.
Old Mar 5, 2006 | 03:20 PM
Morley's Avatar
Morley
No, they didn't have them. I got the NGK's.
Old Mar 6, 2006 | 12:32 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Get the NGK Copper. Excellent plug for your car!
Old Mar 6, 2006 | 04:49 PM
thirdtimevetteowner's Avatar
thirdtimevetteowner
Rapidfire AC's #8, I was told are the best, so I'm gonna give them a try. Will keep this forum posted.
Rich K
Old Mar 6, 2006 | 06:29 PM
Mkos1980's Avatar
Mkos1980
I tell them a tractor lol
To AC DELCO Plug help!! # please
Old Oct 25, 2025 | 05:47 PM
the blur's Avatar
the blur
ac delco r43cts is listed for my motor. They no longer exist...
Believe it or not, I did pull out autolite 26 that has 50,000 miles on them. Car runs great.
Yes I know this is 20 years old, but the motors are 30 years old.
Old Oct 26, 2025 | 10:28 PM
AZSP33D's Avatar
AZSP33D
cast iron heads?
Old Oct 26, 2025 | 11:58 PM
IHBD's Avatar
IHBD
Pro Mechanic
You have the part number wrong.
R43TS is the standard duty taper seat plug used for many, many decades. It still exists on RockAuto for $1.66 each.
There is also a CR43TS. Same plug, but the leading "C" is a "commercial" application with a larger diameter center electrode. Everything else is the same as the R43TS. Rock Auto has CR43TS for the same $1.66 each. I've used both with no discernable difference, I change copper core plugs at about 35,000 mile intervals.
cast iron heads?
My 1988 aluminum head C4 used 3/4" reach gasketed plugs, IIRC, FR5LS. My 1992 LT1 has aluminum heads and it uses a taper seat plug. I put R44LTS in it. I think my 85 (iron heads) uses R45T.
