...and just as I rolled up the brake booster went out. The pedal feels like a cement block. There's a rebuild protocol in the repair manual (1996), but you need the repair kit. Is it worth it? I'm thinking I'll just go with a new one. Here's to two days of tearing it up with the new s/c setup (15 lbs), and nothing to show for it . Let me know if y'all have any tricks for this job to make it go faster.
Your best bet is to replace it with a metal one. I did that on mine after a second plastic one failed, and I could not believe the difference. My brakes were WAY better even when the plastic one was new.
A few long extensions, and 13mm socket, a few stretches before crawling in upside down, and some patients you should be able to have it out in a matter of a 1 hour.
Just pull the master cylinder out of the way gentle, this will avoid the need to bleed the system. Be sure to set the endplay about 1/8", too close you preload the brakes. I check mine by jacking the car up and spin the front tires.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Good thing it didn't happen soon after that. I'm curious if there's any performance rebuilds or upgrades for these, to get more boost.
I haven't been able to locate a metal one that will fit my car (1996 LT4). All the metal ones I've found seem to be for systems 1992 and previous.
Looks like the difference is in the hookup between the pedal and the booster. Any 1996 guys know what the hookup looks like for the booster stock? It's either a clevis style or an eyelet. THanks!
I'm about 20 hours into replacing mine. The few people on the Forum who say it is easy, must have an L98. It is a totaly PITA. I finally got mine out by smashing it with a hammer. Two problems are the cross brace which runs in front of the booster, and it's a lot easier if you go ahead and remove the master cylinder (get speedbleeders to flush the system). I will never do it again. I will gladly pay the shop $200+ to do it for me. I would love to tar & feather the idiot enginerr who came up with some of this C4 crap.
