96 Studdering since 160 thermostat
Old Aug 13, 2001 | 01:59 AM
Shannon1's Avatar
Shannon1
Default 96 Studdering since 160 thermostat
Since I replaced the thermostat my car has been stuttering while in drive at a stop, and I can feel it hesistating while I'm just starting to move. I've reprogrammed with the hypertech computer, but it still is doing it. Is this related to the thermostat or something completly different and just coincidental???
Old Aug 13, 2001 | 09:21 AM
nickd's Avatar
nickd
Default Re: 96 Studdering since 160 thermostat (Shannon1)
Not sure what you mean by reprogrammed,
did you do a custom program for only the fans or are you using the Engine Tuning (performance) program ?
If so try programming it for only the fans, or put the stock program back in and see how the car runs.
Old Aug 13, 2001 | 10:38 AM
88L98's Avatar
88L98
Cruise-In II Veteran
Default Re: 96 Studdering since 160 thermostat (nickd)
id go back to the stock program and just turn on the fans a little sooner. you didnt get any coolant on the optispark when you changed the stat did you?
Old Aug 13, 2001 | 02:56 PM
Camvette's Avatar
Camvette
Your car should not "stutter", by this I guess you mean miss, by using a 160 degree t-stat. Sounds more like a flaw in the reprograming.
Old Aug 13, 2001 | 03:46 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
.... hate to ask but you didn't get the opti wet when you changed the stat did you ...
To 96 Studdering since 160 thermostat
