Dual Mass FW Question
Old Mar 5, 2006 | 06:53 PM
djbraxton's Avatar
djbraxton
Default Dual Mass FW Question
Just finished pulling the tranny on my GS. After I removed the pressure plate and clutch, as I was inspecting the DM flywheel and noticed that I could turn, by hand, the part of the flywheel that is bolted to the pressure plate. Is the normal or is DM toasted?
Thanks,
Old Mar 5, 2006 | 08:41 PM
djbraxton's Avatar
djbraxton
Ttt
Old Mar 5, 2006 | 09:19 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
HOw hard was it to turn and did it go back if you let it go?
Old Mar 5, 2006 | 10:22 PM
djbraxton's Avatar
djbraxton
Bluewasp,
Thanks for the reply, not hard at all and it stays where I put it. With 110k on the OD, I guess it's time...
Thanks,
Old Mar 5, 2006 | 11:33 PM
lcvette's Avatar
lcvette
only a sucker will pay the money for a new clutch and dual mass from GM.. go with the mcleod twin disk for about a grand for everything including new master cylinder and be done with clutch issues forever!
Chris
Old Mar 5, 2006 | 11:39 PM
bogus's Avatar
bogus
I will put it this way... be cautious about what flywheel you do install.
the dual mass will do wonders for quiet with that ZF. Now, the 2nd gen ZF (Blue Tag) is much quieter than the Black Tag.
The steel flywheel that mcloed sells is much heavier than other SMFWs and the twin disk will add more weight, which will do wonders for street drivability.
I donno if I would replace the hydraulics. If yours are leaking, perhaps, but there have been so damned many problems with the replacements, would be a bit nervious.
If you go SM, then be sure to have the new flywheel match balanced to the DM. It will kill any chance of engine vibration. You see, the one piece rear main engines use the flywheel for final balancing.
oh, and to answer your question, the DM in your car is toast.
Old Mar 6, 2006 | 02:17 AM
TOO_HOTTVETTE's Avatar
TOO_HOTTVETTE
The only thing I would add, is to see if you can find somebody that has replaced the dual mass set up and listen to their car and maybe have them take you for a drive. You are going to get plenty of folks who have done something other than OEM. My experience, I hated the noise. Maybe it was made worse by the Hotcam, but I went back and spent a small fortune to go back to the DM set up. Even with the cam I have little noise. I also have the black tag ZF...
Old Mar 6, 2006 | 06:14 AM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Sounds like the spring inside the DM is worn out. I would suggest contacting Bill aka ZFDOC (www.zfdoc.com). I bought a new DM from him a few years ago and the clucth kit. I think the total cost was around $1000.00
I have a street twin on my 383 engine. I think the DM is a little easier to drive.
Old Mar 6, 2006 | 06:20 AM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
no matter what you buy MAKE SURE the imbalance of the stock flywheel is copied to the NEW flywheel. If you go with a street twin or something other then a DM setup you will have to take it to a machine shop to have them balance the new flywheel to the imbalance of the old. LT1/LT4 engines are externally balanced.
You can order a street twin with a GM balance but if your flywheel has weight added then it’s not the standard GM balance. There are holes on the outer edge of the flywheel. If any of those are filled then you need to have the new flywheel balanced.
Buying a new DM flywheel would be easier because you can use DM flywheel weights in the corresponding locations from old to new. No need to take the flywheel to a machine shop.
KEEP THE OLD FLYWHEEL... incase you have a vibration issue you still have the original flywheel.
Old Mar 6, 2006 | 07:28 AM
Red Tornado's Avatar
Red Tornado
this is precisely my experience, every step of the way........used to have the aluminim lightweight fidanza (with matching sprung hub clutch disc -- stage II setup from carolina clutch).....totally hated it.....i mean totally......IMO lousy for a daily driver......i have a black tag ZF......LPE 219 cam.....small fortune back to new DM setup......just a hint of noise/resonance, no problems.......very happy with OE setup.
Old Mar 6, 2006 | 11:47 AM
djbraxton's Avatar
djbraxton
Thanks to all for your comments, I really appreciate it. I'm going to start ordering the parts to do the SM flywheel conversion today.
Thanks again,
Old Mar 6, 2006 | 01:04 PM
bogus's Avatar
bogus
another thing, the DM does not have a spring, it has a rubber-like membrain that holds the masses together.
I have seen pics of these things taken apart. maybe other DMs use a spring, but the C4 DM uses a rubber membrain.
Old Mar 6, 2006 | 01:33 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
I thought the spring is located inside the oil filled rubber membrain.
Similar to this picture.
Old Mar 6, 2006 | 05:06 PM
pablocruise's Avatar
pablocruise
Wrong.
I took apart my 89's DM.
It has a spring and metal flange. No rubber membrane.
Old Mar 6, 2006 | 05:18 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Originally Posted by 89 Paul in Cal
Wrong.
Did you find oil or grease inside? Just wondering.
Old Mar 6, 2006 | 05:21 PM
bogus's Avatar
bogus
Wrong.
what is that in the 2nd pic?
I have seen that pic before.... alone, tho... maybe not provided by you, but someone has presented one very much like that.
Which explains entirely why I have a screwed up perspective on this subject.
Old Mar 6, 2006 | 05:22 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
To Dual Mass FW Question
Old Mar 6, 2006 | 06:17 PM
Atok's Avatar
Atok
The outer flywheel should turn, it is normal. If you read the service manual there is a test to determine if the internal FW damper is bad. I can't remember the specs right now but when I get home I can post the procedure.
Old Mar 6, 2006 | 10:04 PM
~db~'s Avatar
~db~
DJ, don't forget about callaway corvettes. They offer a custom nodular iron SM flywheel balanced per GM spec and a dual friction CF clutch kit. The clutch kit is nothing abnormal BUT the SM flywheel is something that made me lean their way. It weighs more than the AW but less then the OEM DM. Approx 19lbs which I feel is a great compromise. And yes it can be turned. I just bought a kit from them and will install shortly. Would be glad to share the info when done. By the way, I got the idea from one of the boys off the GSR
pablocruise
The 2nd pic.....you mean the Reeses's peanut butter cup wrapper looking thing (LOL)?
That is the thin metal flange I was talking about. It interlocks with that torque limiter's notches(#4 in illustration).
In the channel where the spring resides is a thin film of lubricant.
Not runny fluid oil, but not thick heavy grease either.
