Idle Speed
Old Mar 7, 2006 | 10:33 AM
Demonic85's Avatar
Demonic85
Default Idle Speed
I know this is a dumb question, but what is the normal rpm range a stock '85 automatic should be at idle? I ask because mine runs around 500-650 rpms and that seems really low.
Old Mar 7, 2006 | 10:40 AM
redrose's Avatar
redrose
no problem
Old Mar 8, 2006 | 12:51 AM
Mo_Bandy's Avatar
Mo_Bandy
sounds about right....
Mo
Old Mar 8, 2006 | 01:02 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I always try to keep mine at 700-800, particularly for emissions testing.
Old Mar 8, 2006 | 01:24 AM
Morley's Avatar
Morley
550 RPM in gear should be the factory setting.
Old Mar 8, 2006 | 01:44 AM
Demonic85's Avatar
Demonic85
i've never seen it fall below 560 rpms, so i'm good. I was just asking cause it felt like it was about to die on me when it fell that low. It doesnt do it very often. Thanks guys.
Old Mar 8, 2006 | 07:05 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
You might want to check your IAC pintle and clean it if necessary. Ditto for the throttle body. I make it a point to do this once a year. Really mellows out the base idle.
To Idle Speed
