On the firewall beside brake booster. There are 2 of them mounted together. The one closest to firewall is fuel pump relay and the one furthest from the firewall is the OD relay.
I JUST LOOKED AT THE MID AMERICA CATALOG, I CALLED AND THERE IS NO SUCH RELAY FOR A 4+3 MANUAL TRANNY,IT SAYS IT IN THEIR CATALOG, ANYBODY OUT THERE KNOW FOR SURE
The Helms for my '87 confirms this. The 4+3 transmission definitely has this relay. I would trust AGENT 86 and the Helms long before Mid America
Same part # as the fuel pump relay
Go look under the hood
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
The GM Parts & Illustration Dealer Guide says that the 85 & 86 FP relay and the OD relay are both GM part #14078915. You should be able to get it online or at any auto parts store using the GM #.
