backfiring closed loop only?
Old Mar 8, 2006 | 02:43 PM
jerkyboy's Avatar
jerkyboy
Default backfiring closed loop only?
What would cause this problem? I was out cruising and it felt like the tune was slowly getting fatter and fatter. I started feeling some backfiring in the headers. At light throttle in 5th gear, It would buck initially until It went open loop. Starting from stop and mashing it (open loop) it seems fine. I have had a similar problem before caused by a header leak introducing air to 02 sensor. Exhaust looks ok this time. What gives? P.S. I am speed density and DFI
Old Mar 8, 2006 | 04:06 PM
Blown Vette's Avatar
Blown Vette
Are you using a wide band 02? If not you should consider it. Regardless it sounds like a vacuum leak.
Old Mar 8, 2006 | 08:23 PM
thmupr's Avatar
thmupr
My 89 GTA did something very similar right before the Mass Aiflow sensor went out. Took me a couple days to find it as it would run fine and never set a code, and then just lose power on the highway after I had cruised for a little bit. If you have a spare, swap em and see.
Old Mar 8, 2006 | 09:26 PM
mseven's Avatar
mseven
Have you put a scanner on it to see what is going on? It sounds like it might be getting out of control of the ECM. At a point the ECM can only compensate so much. An 02 sensor could be the fault, but without seeing the numbers (BL and 02)on it, that would be hard to tell.
Old Mar 9, 2006 | 07:36 AM
jerkyboy's Avatar
jerkyboy
I didn't have a chance to datalog yesterday as I had my hands full running the curves on skyline drive
The car wasn't doing this before I uncorked my exhuasts last week (took out crimped bends, replaced with mandrel bends). Let me ask you this, if they guy was welding on my exhaust and ground his welder on the the exhaust, could it have fubar'd the O2 sensor?
The only other thing I have done recently is remove the TB. Even a gasket leak at this location should not affect a speed density system right???
Old Mar 9, 2006 | 09:33 AM
4REGT4's Avatar
4REGT4
bump - I'd like to know the solution to this as well...
Old Mar 9, 2006 | 09:56 AM
FELNGR8's Avatar
FELNGR8
Hey Dave, the run yesterday was great fun. Your poorly running, 500 horse to the wheels, pushing like a pig, old 89 kept up with me just fine!
I viewed the tape and unfortunately the runs up the east side just don't look as fast as they were. That east side is hairy, especially with the gravel and sand on the road from the salt trucks.
I didn't wreck and you didn't break down. Success!!!
Old Mar 9, 2006 | 10:29 AM
jerkyboy's Avatar
jerkyboy
Chuck, great time yesterday. Car runs best when pedal is to the floor
Old Mar 9, 2006 | 11:43 AM
mseven's Avatar
mseven
I don't know if attaching a ground from welding would do that. When you put a scanner on it, and the reading is not "bouncing" around and just staying pinned at 900+, that could be the source. A scanner will tell you more than guessing. I have experienced on mine that IAC being out of range of what the computer can adjust, would add to an existing rich condition while scanning.
Old Mar 9, 2006 | 09:01 PM
jerkyboy's Avatar
jerkyboy
I pulled the o2 sensor and the tip was white. That means that side is running lean correct? I can smell it running rich though. That's wierd. I heard some rattle noise in the end of the sensor. Is that normal?
I reset the TPS values in my DFI. I am not sure what to look at as far as IAC counts. I need to research more.
I could not find any vacuum leaks or unplugged lines? I'm going to replace the o2 sensor. It is a four wire with a #3302 on the side. Anyone know where I can get this particular 02?
Old Mar 9, 2006 | 09:13 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
Hi, often lean cars will backfire on decel/light throttle. They will also have a fish bite feel to the gas pedal.
On top of that lean cars will often stink.
Old Mar 9, 2006 | 09:18 PM
Morley's Avatar
Morley
I have to ask...HUH? What exactly is that?
Old Mar 9, 2006 | 10:00 PM
jerkyboy's Avatar
jerkyboy
Yeah..what's a fish bite feel??
Alvin, on part throttle I actually feel little backfires in what seems to be the headers. Does that follow with a lean condition? My headers were getting hot as well.
Everything was ok until I freed up my exhaust then all of a sudden I'm getting this stuff.
Would my freed up exhaust be scaveging (sp) better and causing this lean condition? The only backpressure I have now are my flowmasters.
P.S. When are you going to come down to NOVA for a dyno tune session?
To backfiring closed loop only?
