E-Prom
Old Mar 8, 2006 | 07:21 PM
fredk's Avatar
fredk
Default E-Prom
I am trying to install my new chip by Alvin and can't figure out how the ECU comes apart. I have tried to search because I know this was discussed about a month ago but can't find it. Can anyone help me out.
Fred
Old Mar 8, 2006 | 07:42 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Fred
There are three 10mm nuts that hold the PCM/ECM (computer) to the rack above the battery. Once you get these nuts off, flip the computer slowly upside down. There are 4 little torx screws you need to take out,a nd the chip will be right underneath that. Then, there are 2 tabs that unlock the chip from the motherboard. Slowly undo them then the chip lifts up. Take alvins chip and plug it into the chip. The chip will be at a 90 degree angle with the top going into the computer towards the motor(I hope thismakes sense), Alvins chip will have the factory chip plug plugged into it on the and then Alvins chip will plug into the factory slot. Does this help?
Old Mar 9, 2006 | 06:39 PM
fredk's Avatar
fredk
Thanks alot Steve, you saved my *** again. I was working on the other end of the ECU.
Thanks again
Fred
Old Mar 9, 2006 | 08:19 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
Hi,
I sent you some install instructions last night via email. If you have any more questions please give me a call.
Old Mar 9, 2006 | 08:25 PM
JOHN89's Avatar
JOHN89
Alvin,
Can you read EASE scan files? I need to send you some for a friend.
John
Old Mar 9, 2006 | 08:41 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
yeah, give me a few hours.. I'm still working off emails from earlier today.
Old Mar 13, 2006 | 05:00 PM
fredk's Avatar
fredk
Thanks Alvin, it was a piece of cake. A picture is worth a thousand words.
Fred
To E-Prom
