Power Steering Pulley removal?
Old Mar 10, 2006 | 10:59 PM
sothpaw2's Avatar
sothpaw2
Default Power Steering Pulley removal?
For the LT1 (early), is there a way to remove the PS pulley without a special tool? The shop manual specifies a special tool which I don't have/not inclined to get.
I'm just trying to swap out the tensioner down there, I have the bolt out but I can't get the part out the top with the PS pulley in the way.
Suggestions?
Old Mar 11, 2006 | 01:49 AM
Morley's Avatar
Morley
Auto parts store will rent you the puller for next to nothing, usually just a deposit that you get back when you return the tool.
Old Mar 11, 2006 | 02:07 AM
robertt43's Avatar
robertt43
Default Tool
i bought my steering unit at Merle's Auto,and they swapped the pulley for free. it's not easy to do,a little tricky
Old Mar 11, 2006 | 02:13 AM
LT1inaMGB's Avatar
LT1inaMGB
Check the sales at Harbor freight. Got mine for about $10, works great.
Old Mar 11, 2006 | 07:50 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Don't try to remove pulley without the correct puller. I borrowed one from the manager of the local parts jobber. Check you rental center or local jobbers for a loaner.
Old Mar 11, 2006 | 09:37 AM
sothpaw2's Avatar
sothpaw2
Ok--I'll see what is around and maybe I'll get lucky.
Old Mar 11, 2006 | 11:15 AM
MikeC4's Avatar
MikeC4
don't forget you will also need a PS installer tool. Pep boys has the GM removal/installer kit for reasonable price.......
Old Mar 11, 2006 | 12:37 PM
Muffin's Avatar
Muffin
What Morley said. I got a thing for tools but can't see buying one,at any price, that I will use once especially when I can use one for free.
Old Mar 11, 2006 | 03:08 PM
AGENT 86's Avatar
AGENT 86
A bolt and a couple of greased washers works just fine
Old Mar 13, 2006 | 05:09 PM
CAP94's Avatar
CAP94
thanks
To Power Steering Pulley removal?
