So, is there anything im missing???
In your current configuration I would worry at all about the TB, and as long as your pump holds pressure at WOT, you will be perfectly fine with what you have. gears, unless they are 2.XX I would not worry about them either.
As far as ET/MPH, I would say you should easily see 12.7@105MPH if everything is sound. And depending on how well you can stage (shallow) and how well you can drive the car you could see as low as 12.5sec.
Shift with that intake no higher than 4700rpms. Which will require you to manually shift the car. If you let it shift on its own, it will be WAY too far past the power before it shifts on its own. I would watch the stock dash and shift when you think its at 4200 and by the time you react and the tranny shifts it will be around 4700.
For future items to look for to boost your performance - hands down a super ram intake manifold and base should be high on your list.
Good luck and let us know what you get!
-free up the air filter,
-shift-kit, or sharp adjustment on TV cable,
-3.07 gears, at the least..
I have lately driven two 89's..one with 2.73 and the other with 3.07's...there is a BIG difference in the way these cars perform, esp. from take-off..
IMO the 3.07 is a good all-round ratio...at 65mph 2000rpm I don't consider to be too high, and it offers spirited launches.
Sounds like you are putting together a sweet all-rounder...
What cam grind did you use? I'm considering the Comp XE262-H14
That doesn't sound like a 12 second car to me, but if it is, then I'll be writing some checks soon.
Someone above stated to adjust the TV cable, I am guessing he meant to firm up the shifts.
IT is NOT advisable to do this, if you want an A4 to shift tighter etc. parts need to be changed.
duration @ .050 Intake=212 Exhaust=212
Lobe Lift .2960
lobe seperation 112.0
I fully understand about the TV cable. The price has came down on the super ram, and that i like. If I dont go with nitrous, i will defiently slap that on. Ill keep ya updated when i get HP and 1/4 Mile times.
Maybe down the road get a little bigger cam, Miniram and some more gear. What you have should be fun to play around with as a driver.
No problems with vacuum and streetable from what iv'e read. I can't comment on it much as i've just started the build. Haven't read anything but good about it and was the cam that comp recommended for my 355 rebuild (for my driving style)
