AFR180 Head/Valve Cover Gasket sealing problem
Originally Posted by mseven
The gaskets that corvette 0096 posted look real good, and may give the additional height required to use your new covers.
Originally Posted by robs87vette
I've looked all over for these in Centerbolt and I've concluded they don't make them. Probably not enough demand.
I don't know but I wonder if they would be ok just the same.....maybe just trim off the hole tab.....HHHmmmmm, maybe a PM to 0096 might help.
I read were guys here had to trim the lip of the proforms. I have the same in wrinkle blk. and there is a little lip around the whole thing and an extension in the corners. I did not have to trim any of it off. all I did was use a little sealer around the mating surface of the cover itself than stick a OEM gasket (GMP for the covers) to it and mine are sealing (hopefully stay like that). Maybe the mounting lip on these AFR's heads differ from one to another due to the machining? Would seem strange, but I guess a possible reason.
GRX I would think you should be able to tell (feel it covering the lip)when you try a cover on it w/no gasket on the heads.
That sux, those are the best ones I have seen to date.
