LT1 AIR pump delete
Old Mar 9, 2006 | 01:28 PM
ThingFish's Avatar
ThingFish
Default LT1 AIR pump delete
The AIR pump on my '92 LT1 is really loud. Up till now I've just ignored it and waited for closed loop so that it would shut up. I could replace it but I rather just disconnect or disable it. I tried simply unplugging it but got an idiot light. Can anyone advise how to disconnect this thing without the engine knowing? :-)
BTW, I searched like a good boy and didn't see this asked.
Thanks!
John
Old Mar 9, 2006 | 01:52 PM
thmupr's Avatar
thmupr
I unplugged mine on my 92 without getting a light. What code did it set?
Chris
Old Mar 9, 2006 | 02:14 PM
CE_Vetteboy's Avatar
CE_Vetteboy
I transplanted a '94 LT1 into a '88 S-10 and never used the air pump. The SES light never comes on. (Because of that anyway)
Old Mar 9, 2006 | 02:25 PM
93 ragtop's Avatar
93 ragtop
My 93 comes on when I disconnect mine. I actually had it hooked up electrically, for awhile but the hose not connected and it sounded like a shop vac under the hood. Mine is getting till it wines when it is on so I know what you mean by the sound. If I were you, I would send a e-mail to www.pcmforless.com and ask Alvin if it can be programmed out. But my concern would be how will it effect an emissions test and will it harm the converters by not running.
Old Mar 9, 2006 | 04:16 PM
jstkrsn's Avatar
jstkrsn
Default Pump
I could sware my 92 doesn't have an air pump. I put shorty headers on and there are no air line hook ups.
Old Mar 9, 2006 | 04:57 PM
93 ragtop's Avatar
93 ragtop
Its an electric pump on the drivers side down under the headlight bucket.
Old Mar 9, 2006 | 08:45 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
Thanks.
There are also some biasing the computer uses when the airpump is active.. I remove those but it shouldn't cause any noticable difference.
Can I ask.. Why remove it? it doesn't help performance any.
Old Mar 10, 2006 | 02:30 PM
ThingFish's Avatar
ThingFish
I didn't check the code, cuz I knew why the light was on. Hooked it back up and the light was off.
By "programming it out" I presume you mean a custom PCM chip which doesn't throw a code. Neat idea but for that amount I could probably replace the pump (presuming a new pump would be quiet).
What I'd really like to do is "hotwire" the connection so the computer thinks the pump is still there.
John
Old Mar 10, 2006 | 06:41 PM
93 ragtop's Avatar
93 ragtop
That might work. I just dont know. I do know when I first put my headers on and did not have the pump tied in, it would set a code and turn on the light. With the pump plugged in but not plumbed, it sounds like a shop vac. Good luck, and let us know if you find a way to bypass it without programming it.
Old Mar 10, 2006 | 06:42 PM
93 ragtop's Avatar
93 ragtop
By the way, I think your avatar is cool.
Old Mar 11, 2006 | 01:56 AM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
With me the car fixed its self. The pump was bad when I got the vette so pulled everything out. The light was on for about two months then one day I went to start the car there was a pop and everything was dead. When I started to unhooked the battery I could hear the relay clicking. I hooked the battery back up and everything was fine. Sense then no light and no code.
Old Mar 13, 2006 | 08:52 AM
ThingFish's Avatar
ThingFish
I've shopped around and finding a replacement for this pump is HARD and the one that I did find was EXPENSIVE, like over $300. Surely (Shirley?) others have encountered this problem and simply disconnected the pump as I did, encountered the code as I did, and figured out a way to trick the ECM into thinking the pump was operating normally. So, I will ttt this thread one more time.
TIA!
John
BTW, glad you like the avatar. Title of the image is something like "Winner of the 'not my job' award"
Old Mar 13, 2006 | 12:20 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
If all you want is the Air pump stuff removed I can do it for say lunch plus what the adapters cost me.
Old Mar 13, 2006 | 01:22 PM
ThingFish's Avatar
ThingFish
That's all I want. I agree to your terms so long as you provide your own transportation to Ohio!
Seriously tho, if you know of an adapter I am all ears! Keep in mind that this is a '92 LT1 with an electric AIR pump, not an L98 with a pulley driven pump.
John
Old Mar 13, 2006 | 02:18 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
I don't think you understand what I mean..
I can burn a memory adatper chip that plugs in between your stock chip and stock computer. It will have the stock program on it minus the Airpump checks and enrichers.
On another note I will be in NE ohio doing a tuning day in the next month or so
Old Mar 13, 2006 | 04:29 PM
ScaryFast's Avatar
ScaryFast
Great, I'll bring my car down, too, with a wad of cash. Where in NE Ohio?
I'm replacing the timing chain and upgrading to the '95 Opti. If that doesn't fix my problem I'm hosed. Racing season starts April 1...
Old Mar 13, 2006 | 04:30 PM
ScaryFast's Avatar
ScaryFast
Thingfish - I might still have my AIR pump from my '93. I'll check, and if I do you can have it for shipping.
I think I might have sold it on Ebay, though.
Old Mar 14, 2006 | 09:48 AM
ThingFish's Avatar
ThingFish
Wow, that would be most excellent. Yea, please check and let me know if it's still around.
BTW, I've taken the thread with Alvin to PMs to see if he can burn me a chip.
John
To LT1 AIR pump delete
