My crazy engine idea
Old Mar 10, 2006 | 09:37 AM
Fastmax32168's Avatar
Fastmax32168
Default My crazy engine idea
This is for those of us that think too much. I have had this idea in my head for many years now. I have always wondered how a motor would workout if I built it with two different sets of specs.
IE have a camshaft ground where four of the cylinders were more radical than the other 4. Nothing radical different, perhaps 10 degrees more duration in 4 than the other. Install larger valves and port the heads larger on 4 of the cylinders, install larger header tubes on 4, possibly even use a tuned port and run 4 of them with big long tube runners while siameseing the intake short on the other 4. The idea of all this being to create a motor that had 4 cylinders picking up the power down low and 4 that would keep pulling strong up top. Thereby creating a very wide power curve. Of course you would have to balance everything out so it still ran smooth. I doubt I am the first person to think about this so I was wondering if anyone has ever heard of it being done or done such a thing. Thoughts on the matter?
Old Mar 10, 2006 | 10:23 AM
Gold1986Vette420's Avatar
Gold1986Vette420
Sounds like a bad idea. It would be down in power at its sweet spots in the 2 different cam ranges compared to the identical 8 cyl. setup on either setup.
Your best best is to build the bigger better setup and offset the torque loss by either a torque converter change and gearing (auto) or gearing on the manual.
10 degrees isn't extreme, probably a couple of hundred rpm diff. so why go through all the crazy porting and matching. spend your money on a good set of heads, a good intake and a decent cam and you wont be disappointed.
Old Mar 10, 2006 | 10:40 AM
Ramanstud's Avatar
Ramanstud
of course, there's always variable valve timing.
Old Mar 10, 2006 | 11:29 AM
GeosFun's Avatar
GeosFun
I think someone just has to try it. You might have something that more or less defies conventional logic. Who would have thought changing the firing order/crank throws would pick up power (witness current pro-stockers) or moving the location of a blower forward on the engine would make more power? or throw in a couple of extra valves from 2 to 4, etc.
Shoot, if you look at the current heads and cams in the LS-series small blocks, they would not pass smog or make decent gas mileage in a million years on our older "standard" SBC's. But they make oodles of "clean" power and decent manners, all due, I believe to computer controls.
Old Mar 10, 2006 | 11:52 AM
comp's Avatar
comp
Old Mar 10, 2006 | 12:20 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I would think your power curve would be short and steep and not too tall:
You'd have a worse low end than an all-mild engine and a worse top end than an all-wild engine.
Who knows for certain, though?? Try it and keep us informed!!
Larry
code5coupe
Old Mar 10, 2006 | 12:24 PM
cv67's Avatar
cv67
St. Jude Donor '05
Dont think it would work, different cylinder pressures/backpressure on each bank, reversion through the intake on 4 cyl's...jmo.
Old Mar 10, 2006 | 12:28 PM
kopbet89c4's Avatar
kopbet89c4
You are thinking of Honda VTEC!! Good engines, but all torqueless.
y0 y0 y0, i g0ts t0 w4it f0r t3h VTEC t0 kick in!!!
Old Mar 10, 2006 | 12:57 PM
Demonic85's Avatar
Demonic85
Yeah thats the biggest problem I have with import cars. Most of them are front wheel drive and they all have more horsepower than torque. For me torque is where all the fun is with burnouts and all that good stuff. I just love the classic american muscle design.
Old Mar 10, 2006 | 01:07 PM
kopbet89c4's Avatar
kopbet89c4
I'd rather you buy those custom 4 valve heads than do this. About the same price as a S/C, but the difference is that you are all motor and about as strong. I see they make them for 1st and 2nd gen SBC motors. Damn I forgot the website already...
Old Mar 10, 2006 | 03:16 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Originally Posted by comp
Old Mar 10, 2006 | 03:26 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Interesting. It doesn't involve any new technology either, should cost the same as any other buildup, except for the custom can grind.
And if it didnt work out, you could just pull the heads and do valve on the other 4 cylinders, and you haven't wasted anything except some setup time at the machine shop, a cam, and labor.
Old Mar 10, 2006 | 03:49 PM
blown87's Avatar
blown87
GA Events Coordinator
x2
Old Mar 10, 2006 | 03:56 PM
jordis's Avatar
jordis
if you got the spare crap sittin around go for it. if it doesnt bankrupt you, then havin a little fun couldnt hurt. if it doesnt work, then you know not to try it again, if it does somehow work, then you may be onto something big if you can fine-tune it. much like the mazda rotary (although hopelessly torqueless) which can produce great power for being like a 1.3L...new ideas, even if they fail, are what lead to innovation. i say go for it and if it works dont tell anyone
CJ
Old Mar 10, 2006 | 04:22 PM
comp's Avatar
comp
lets not forget cranks break
Old Mar 10, 2006 | 05:13 PM
1991Z07's Avatar
1991Z07
Although, why do you think you'd have a loss of torque???
My 355 with larger valves, CNC-ported heads, big-tubes and headers cranks out nearly 500 lb/ft...
Check the build on my homepage...
Old Mar 10, 2006 | 05:51 PM
cv67's Avatar
cv67
St. Jude Donor '05
One bank could make 300 lbs of torque at 2000 rpm, but say the other (wild) bank made 200 torque at 2000 rpm. It wouild seem youd have the power of smaller engine. When it "came up on the cam", yoiud onl;y have 4 cyl's making real power.....Unless
You increased the stroke on the wilde side by 1/2"
Its not a bad idea though, thats how better designs are born. Personally I like the 4 valve approach. In '90, GM was already aware that 500 chp was easy to get out of the LT5 but then the LS1 engine would never sell. Guys are getting close to those #'s all day long on those motors with stock stroke, cams and bottom end, simply do a thorough porting from the TB to the heads, some LT's and your there.
Imagine what another 15 years of technology would have done. Maybe a DOHC 6.0 with LS type ports?
http://www.araoengineering.com/
http://www.valleyhead.com/main.html
THese heads have been around forever....Ive stopped in to ARAO before, thats one big hunk of aluminum. THey are 4valve heads, but not DOHC: Still make big power though-
To My crazy engine idea
Old Mar 10, 2006 | 05:55 PM
Fastmax32168
I appreciate the desire to help me out but you guys that are saying build it the conventional way are missing the point of my post. Its an experiment and the whole idea is really just a discussion. I already know it will work the way its always been done. I honestly will probably never get this idea done as I have probably built 5 or so motors the conventional way since I first thought of this.
I just wanted to know if I really am and was looking for discussion on the idea. I was also wondering if anyone else out there is also and may have tried it.
Roy
Old Mar 10, 2006 | 08:14 PM
Ricks94vette's Avatar
Ricks94vette
Default Engine
If you have that much time, I could use someone to rebuild my engine.
Old Mar 11, 2006 | 03:25 AM
Gold1986Vette420
[QUOTE=cuisinartvette]One bank could make 300 lbs of torque at 2000 rpm, but say the other (wild) bank made 200 torque at 2000 rpm. It wouild seem youd have the power of smaller engine. When it "came up on the cam", yoiud onl;y have 4 cyl's making real power.....Unless
QUOTE]
Although
If you want good clean power though the rpm range build a LSx type of motor. The head design is superior and makes more power over a broader range, is a lighter and more efficient package, and has been known to make 500+rwhp on a stock bottom end 346 with just heads, cam, intake, and exhaust.
