Got in the car (95 Cpe, w / mn6) the other night, interior lights came on, turned the key, the starter turned once and everything went dead. No lights anywhere, nothing. The door lock button will make noise, thats it. Hooked up jumper cables, interior lights came on, turned the key, everything went dead again. Came back next day, put in a new battery, car started right up. Let it run for 5 minutes or so, shut it down, fired right back up. Came back 10 minutes later, turned the key, starter clicked once and everything went dead again, same as before. Unhooked the battery cables, let it sit for an hour or so, hooked it up, still absolutely nothing except door locks will whine. When the battery is connected, there is a clicking noise from inside the passenger side dash, stops when you turn the key to run position. I am at a total loss, any ideas? Thanx in advance...
Are you sure you don't have a bad starter? try this, try starting-if just a click take a pipe reach down and rap the starter a couple times, if it now starts you know what the problem is. The ticking sound could be from the sentry light timer-just a thought.
with the key turned to run posiyion only, what does your dash voltmeter read with youe new Bat? when you try to crank, does the voltmeter take a dive below 11V ?? If you turn your headlights on, do they popup and illuminate?
There is no power to anything, the dash lights will not come on, no headlights, no interior lights, nothing.
sounds like you have a short in your starter motor. When you installed the new Batt, did you see sparks jumping when you hooked up the terminals? Have you checked first for blown fuse???
You have a second dead battery (battery voltage below 12.0 volts) because your leakage current is high enough to discharge the battery overnight. Remove the negative cable from the battery and charge your battery up. Then connect an ammeter between the negative cable and the negative post on the battery and wait for the courtesy lights to time out and then switch your ammeter down to lower full scale current to measure the leakage current. GM says leakage should not exceed 50 milliamps, my 87 measures 27 ma.
At night, connect battery and look for underhood lights on, vanity mirror lights on, console compartment lights on. Do you have a radar detector, aftermarket alarm or radio or audio power amplifier? Check em. Next pull the courtesy light fuse so you can keep the passenger door open and pull fuses one at a time and watch the ammeter for a drop in current. The fuse removal will locate the circuit drawing excess current. I'm not familiar with the 95, but there are about 8 circuits that use a fusible link and you need to disconnect those wires one at time if removing fuses doesn't find the leakage.
read his post again. He let the car sit for 10 minutes, and the battery went kaput, not overnight. Small leakage current is one thing, but this sounds like a high currentt dead short.
Could be, but then soemthing should have been burning. I would lean towards bad primary cable connections. Usually, but not always, it is the battery to ground connection.
aminnich- very good point, with that much current flow, surely a fusable link would blow first or wire insulation would fry smoked and smell to high heaven...
The first two starts on the new battery killed the battery and thats why it won't start the car. The evidence is the clicking relay which indicates too low a battery to even turn on the courtesy lights. Of course that might not be the cause and can be verified by measuring the battery voltage to determine the state of charge. 12.0 volts and below, discharged. 12.9 volts and above, fully charged. Also, measure the battery terminal voltage while attempting a crank, the battery should not fall below 9.0 volts or the battery is discharged, cable connections are poor, or the battery is at the end of its life (no matter what the age of the battery is). Another possibility if the cable connections are bright and tight, is a defective cable, that is, the connection of either cable wire to the battery lug on the cable. Furthermore, I would check the quality of the battery ground wire connection to the frame. Also, check the quality of the connection from the battery positive to the ignition switch, it may have a defective fusible link.
Got it fixed. Thanx everyone. I disconnected the starter and everything came alive, so I replaced the starter, turned the key and drove on! Thanx again.
You might have a ground problem also. Try removing the ground from the battery where it connects to the frame and clean it with a wire brush and make sure it is bolted on tight. I had a problem like yours and the negative cable had rattled lose from the frame. Let us know what the problem is once you figure it out.
