emergency help needed
Old Mar 11, 2006 | 04:48 PM
rightofway's Avatar
rightofway
Default emergency help needed
i can't get the bolt that holds the lines to the back of the compressor off, it will not budge and started to round off. i don't want to break anything
please help
Old Mar 11, 2006 | 04:54 PM
Morley's Avatar
Morley
Soak for several hours in PB blaster and try again.
Old Mar 11, 2006 | 05:53 PM
Radioshop's Avatar
Radioshop
Sometimes a good solid whack to the head of the bolt will jar things loose. If that does't work, try heating it some with a torch.
Old Mar 11, 2006 | 06:40 PM
rightofway's Avatar
rightofway
alright i got that one
but does the valve cover have to come off to get the compressor off?
Old Mar 12, 2006 | 03:13 PM
Radioshop's Avatar
Radioshop
It's easier to remove the bracket holding the compressor as a unit, then you can seperate the compressor easily. There is a torx head bolt holding it on there (and I think a couple more) that has a clearence cut out on it so it'll clear the edge of the compressor when it's in just the right spot. I fought this because I thought the clearence cut was a facet on a hex head bolt. Eventually with an inspection mirror, I saw the light. I also have an 86. Good luck.
To emergency help needed
