ses for iat sensor
Old Mar 11, 2006 | 05:31 PM
rickthejetman's Avatar
rickthejetman
Cruising
Default ses for iat sensor
o.k. corvette gurus i have a mighty perplexing problem. i have just finished a performance rebuild heads cam pistons and a chip from pcmforless. and now it runs pretty good except when you go into reverse or drive the idle bogs way down and sometimes stalls. then the ses light comes on and i get a code for iat sensor? that does not make sence i have checked for vaccum leaks,iat wiring,min idle speed,tps adjustment,timing,and just about every other thing i can think of. it is an 86 auto with dartpro 180cc runners 64cc chambers, crane 262 zcam,10.5 to 1 comp.and a granetelli maf. and chip from pcmforless.
please help! thanks Rick
Old Mar 11, 2006 | 05:57 PM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by rickthejetman
...the ses light comes on and i get a code for iat sensor? that does not make sence...
That "does not make sence"? What does your factory service manual say causes the code you received? If you follow the trouble shooting chart(s) for that code, you are likely to find the cause.
RACE ON!!!
Old Mar 12, 2006 | 04:55 PM
rickthejetman
Cruising
i went to the link provided and they dont sell my service manual anymore. so if anyone out there has this info i would greatful
Old Mar 12, 2006 | 08:03 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
Hi,
You may want to get a scanner on it. If the scanner shows a temperature way below zero you likely have a short or faulty sensor. The car will run richer than it should with the IAT malfunctioning so I would try to fix it asap before you foul a set of plugs.
Old Mar 12, 2006 | 08:41 PM
CFI-EFI's Avatar
CFI-EFI
How did you determine that? Couldn't you click your way around to HERE?
RACE ON!!!
Old Mar 12, 2006 | 09:02 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/corvette86/Code%2023.pdf
http://members.shaw.ca/corvette86/Code%2025.pdf
To ses for iat sensor
