tach filter
Old Mar 11, 2006 | 05:34 PM
rickthejetman's Avatar
rickthejetman
Cruising
Default tach filter
hi guys. my tach filter has gone bad and the dealer said it is discontinued. so does anyone know where i can get one or can i just run without and wire around it?86 auto coupe
Old Mar 11, 2006 | 05:38 PM
CFI-EFI's Avatar
CFI-EFI
The tach on my '84 works great (at least, well) without a tach filter.
RACE ON!!!
Old Mar 11, 2006 | 06:29 PM
VtVette's Avatar
VtVette
My tach filter was bad as well. CFI-EFI informed me that he runs without one in a previous discussion about this same topic a few months ago. If you've been here for any length of time you know he is very knowlegable and helpfull. If he says it runs well without it that is good enough for me. The tach wire plugs directly into the distributor with the section of wire containing the filter removed. I have not started my engine yet with the tach filter removed so I can't speak from personal experience.
Please post your results if you choose to bypass the filter on your car.
Old Mar 11, 2006 | 07:51 PM
MR NICE's Avatar
MR NICE
Let us know if you can bypass it,I have the same problem.
Old Mar 12, 2006 | 04:49 PM
rickthejetman
Cruising
o.k. gang i bypassed the tach filter and everything looks o.k. so far. the tach is working again and it is not doing anything irregular.thanks fr the help guys
Old Mar 12, 2006 | 04:52 PM
rick lambert's Avatar
rick lambert
that's great to know
Old Mar 12, 2006 | 05:24 PM
MR NICE's Avatar
MR NICE
Old Mar 12, 2006 | 05:46 PM
VtVette's Avatar
VtVette
Great to hear. This should be added to the Tech tips.
Old Mar 12, 2006 | 09:01 PM
CFI-EFI's Avatar
CFI-EFI
You da man rickthejetman. Why didn't I think of that?
RACE ON!!!
Old Mar 13, 2006 | 01:20 PM
JAKE's Avatar
JAKE
I haven't tried running my engine with my tach filter disconnected, but I'll keep that info in mind incase I ever have a filter problem.
If you JUST have to have the filter, I've seen one advertised for sale in one of the catalogs. Forgot which one specifically, but it was one of the Vette catalogs; Mid America, Corvette Central, Ecklers, etc.
Jake
Old Mar 13, 2006 | 03:09 PM
Nico's Avatar
Nico
From: 1984 crossfire, Alhaurin de la Torre Malaga, Spain
I did run without a filter in my 84, but considered it a bit risky for my instrument panel.
When I measured one, it contains an inductor and one or more capacitors. So It may protect your cluster from voltage spikes. So if you feel unconfortable, I may be able to measure the filter and tell you how to make it from low cost RS materials.
Tell me if it is worth doing, I feel happy to help if one thinks it eases his mind.
Old Mar 13, 2006 | 07:56 PM
CFI-EFI's Avatar
CFI-EFI
Maybe I've just been lucky. I really don't know much about electronics. A wire broke off of my filter, I bypassed it, and it has been trouble free for years. I don't know anything about this guy. I've had the link for years, but never used it. The fact that the site comes up is encouraging. Check HERE if you want to look into a new tach filter.
RACE ON!!!
Old Mar 13, 2006 | 08:47 PM
Red Tornado's Avatar
Red Tornado
when mine went kaput i had no choice but to go to a salvage yard. the 90/91 tach filters are without replacement. i got a good used one, wrapped it in heat tape, installed it and voila, my tach relaxed and went back to normal after going literally haywire for 2 months.
i'm not comfortable with the bypass solution.
Old Mar 14, 2006 | 09:50 AM
89corvetteken's Avatar
89corvetteken
I have one off my 89 that you can have for $25 delivered.
When I put in my new 383 I lost the original and purchased a used
one from contemporary corvette for $50 PLUS SH.I just recently found
my original in the basment and now I have 2.
Old Mar 14, 2006 | 12:41 PM
hz900's Avatar
hz900
I just got my 383 running this past weekend, thanks to CFI and others no less, and part of the rebuild required a used engine harness to replace the original. The used harness had already had the filter removed so I went with it like it was and although I haven't run it for very long period of time yet, it seems to operate fine. I've got a '90 model.
Old Mar 14, 2006 | 03:41 PM
85blkrose's Avatar
85blkrose
have you tried here yet.
http://www.parts123.com/parts123/yb....Z5Z5Z50000050F
To tach filter
