Recommended Shift Kits
Old Mar 11, 2006 | 06:05 PM
qws's Avatar
qws
Default Recommended Shift Kits
Got my engines mods all done today and the car is running awesome. What a differance......... feels like a new car.
Now I was told that I should get a shift kit put in. What do you guys recommend? or any other tweaks I can make for improved shifting. Next winter I am doing gears but nothing to radical. I thinking something like 3.54
Old Mar 11, 2006 | 07:07 PM
Lichen's Avatar
Lichen
I'm assuming that you have an LT1 A4? Then 3.54 is an excellent choice along with a 2500 stall converter and either a Trans-go or a B&M shift-kit. It will definatly make a big SOTP differance.
Old Mar 11, 2006 | 08:54 PM
qws's Avatar
qws
I have the 700r4, the car is an 84
Old Mar 11, 2006 | 10:56 PM
Pete K's Avatar
Pete K
Ed, if you are comfortable with going deep into the trans, transgo is the one. B&M is a simpler kit that shifts very firm. Some say too firm. I enjoy mine though. Thanks too, for your help. I am going to let Nico and Marc weigh their options. Your help is appreciated.
Old Mar 12, 2006 | 12:39 AM
Brimis's Avatar
Brimis
When I had my transmission rebuilt back in July 2005, I had a shift kit installed. 1st gear shifts very hard, as a matter of fact to hard. 2nd isn't that bad. At first I liked it, tremendous exceleration in 1st gear, tires chirping going into second.
I will probably have the kit removed in favor of a stock transmission. Like you I also have a 84 with the 700r4.
Old Mar 12, 2006 | 12:49 AM
chevy406's Avatar
chevy406
I have a great shift kit down in my basement for you. It comes packaged in an aluminum case. It also includes a new input and output shaft... aka the ZF 6-speed manual.
Old Mar 12, 2006 | 08:17 AM
Nico's Avatar
Nico
From: 1984 crossfire, Alhaurin de la Torre Malaga, Spain
I also have an 84. What mods do you have to make the 84 run that different I am curiuos
I wil keep you updated about the mods Pete did build in my tranny. I asked him to keep it a litlle low though because I do a lot of urban driving. A high stall converter may be less street confort in this case. I asked for a compromise somthing 1600 - 1700. He did give me the foot on the floor through all (how should it be called Pete?) and strengthened the tranny by better clutches and kevlar bands. So I am REALLY looking forward to try it. Also because of the urban driving I asked for a lock-up both in third and fourth in order to lower dissipation in the third. I will be driving a lot of third gear. So my choices may not be yours due to other driving circumstances.
Keep you posted!!
Old Mar 12, 2006 | 08:28 AM
qws's Avatar
qws
So from what I'm seeing the b&m kit is a easy kit to install with very firm shifts? Can a do it yourselfer install this?
The trans go is a harder kit to install but not as firm when shifting?
If I go with the b&m kit and install it myself is there anything else that should be done while having the transmission pan off the car?
I just don't want to find out after a kit gets installed that there should have been something else done while in there.
thanks
Old Mar 12, 2006 | 08:35 AM
qws's Avatar
qws
I did end up going with the x-ram. Was I impressed when I recieved it in, NO. overpriced, YES
After the install.... I love it . I don't care about the price at this point.
But don't do this alone... I've added headers and the 1:6 rockers.
When I first drove it yesterday the low end was much different than before and on the highway I was driving about 75 and gave it just a little gas and hit 115 in no time. Big differance all the way around.
Old Mar 12, 2006 | 09:27 AM
Muffin's Avatar
Muffin
The B&M shift kit is very simple to put in. I did one as a part of putting a B&M Master kit in my 85.
Pete can correct me if I am off base here but the 84 700R4 left a lot to be desired. There were some major improvments made between 84 and say mid 86. If yours is still stock, not updated, a substantial power increase may be more than it can handle.
Let me echo the comments about the B&M kit. 1-2 will snap your neck. It is downright hard. 2-3 is crisp, not hard but you know when it happens. 3-4 is can be felt but is very nice.
Old Mar 12, 2006 | 10:02 AM
Pete K's Avatar
Pete K
Keep you posted!!
Nico, wide open 3 to 4 upshift valve will allow high speed cruising. Later vettes had them but 84's did not. I have stingraymarc's very close to complete and should be sending them to washington dc in the near future. Marc wanted a higher stall, so we have him in the 2800 area. I will shoot you a pm whent they are ready to go with specific details.
Old Mar 12, 2006 | 10:07 AM
Pete K's Avatar
Pete K
84's were terrible by comparison. That is why we started with an 88 core for nico. The 2 main torque holding parts are the foward sprag and lo roller clutch (rear sprag). 87 and ups use a 28 element unit. The replacements use 29 elements (late style only). 84-86 used a 26 element that is not upgradeable. Guys love or hate the b&m kit. I am a fan.
Old Mar 12, 2006 | 08:00 PM
qws's Avatar
qws
What are the part numbers for the B&M shift kit and the Transgo Kit?
Using the stock transmission and since I've added close to another 75-100 hp to the engine (give or take) and if I use a shift kit, is it apt to tear the existing tranmission apart? The firm shifts don't bother me at all.
Old Mar 12, 2006 | 09:48 PM
Pete K's Avatar
Pete K
B&M is 70235. it includes a filter and gasket.
Transgo is 700-2&3 it does not contain a filter and gasket.
B&M retails for about $65
Transgo about $100
In my opinion, they only help them live longer.
Old Mar 13, 2006 | 05:19 AM
qws's Avatar
qws
Thanks Pete, when searching I found a few different kits and just wanted to be sure of the part number. Thinking maybe of the B&M kit
Old Mar 13, 2006 | 07:33 AM
Pete K's Avatar
Pete K
I forgot that transgo may require the purchase of a .500 boost valve and a new pair of white accumulator springs, if you choose the firmness setting that requires them. If you decided to go transgo, you may want to order these with the kit. They cost approx $25
Old Mar 13, 2006 | 02:37 PM
Nico's Avatar
Nico
I am looking forward to it Pete!!
I guess Mark will be here in the south of Spain the last week of april. So we can meet, very nice. Its a pitty that you are that far, I should have bought you a fine dinner and a nice evening at the coast.
I can immagine that Marc has a higher stall converter. You can drive fast in Germany. And he is the guy to enjoy that as well when I see his foto in his profile. Many highways without limit there. Here its a lot more urban driving.
To Recommended Shift Kits
Old Mar 13, 2006 | 02:46 PM
Nico's Avatar
Nico
That is good info, thanks. I like to stick to the CF intake, so I have to work real hard at it to give it some air. I will weld the channels up in order to increase the area and increase the plenum volume to over-compensate for the loss of volume.
After that I will follow what you did by taking 1.6 RR rockers and an other headers. When done correctly, should come close to your performance I suppose.
I am very interested how your new gear does perform with the engine mods.
Please keep us posted about the results.
Old Mar 13, 2006 | 03:20 PM
Aardwolf's Avatar
Aardwolf
Pete, in the part numbers you posted, the B&M one is for the transpak kit. Is this better to use then their basic shift kit?
Old Mar 13, 2006 | 04:49 PM
Pete K's Avatar
Pete K
To be honest, I don't know. The number i listed is the only one I have used.
Nico, Marc's is nearly complete and I have no choice but to figure out how to get them to washington dc. Marc has a special gm crate which will make it easy to fed ex, truck ship or ups. Yours I must send truck. Either way though, good things are coming shortly. Thanks for the kind words. I do appreciate it
