master cylinder grommets
Old Mar 12, 2006 | 09:15 AM
tigmaned's Avatar
tigmaned
Default master cylinder grommets
guys, is it possable to just get the two rubber grommets that are between the plastic resevoir and the metal part of the master cylinder? mine being 20 years old, both grommets are all cracked out and leaking brake fuild and i am sure letting air into the system. if do find them is it just pull the resevoir off and put the new grommets in? and i am sure bleed the system again.
Old Mar 12, 2006 | 10:22 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I dug up this number from the GM parts manual 14067532
I haven't searched if it is still available.
Pete K's Avatar
Pete K
Buy 3 new ones before you begin. They are very inexpensive. I say 3 because I always seem to monkey up 1 of them
To master cylinder grommets
