Starts running and quits...
RACE ON!!!
I assume that the pump cycles to prime the system, but does the pressure hold if you don't crank the engine and leave the key on? If the pressure drops off quick, then your pressure regulator should be looked at.
BTW what is the pressure?
If the pressure holds, then crank the motor up and watch the pressure. If the pressure drops as you crank, its in the fuel pump circuit, but may not be the pump itself.
The oil pressure sending unit is supposed to keep the pump running while the engine is running. With the key on, short the oil pressure sending unit to see if the fuel pump relay clicks on. Click with no fuel pressure means you are going to have to yank the pump out again.
Good luck and keep us posted
and it drops quickly-you probably have a bad injector(s) leaky.
RACE ON!!!
RACE ON!!!
Do you have a noid light?? If so, connect it across a fuel injector plug, bet you will see no 12v while the engine is cranking, this indicates the ECM is not receiving feedback pulses...
Get a service manual to trace out the wiring to the ECM from the distributor, it should also have tests to detirmine if the pulse module is bad....
Herris
No VATS in 1985.....
