Lingenfelter Headers
Old Mar 12, 2006 | 05:10 PM
L-9ate's Avatar
L-9ate
Default Lingenfelter Headers
1991 L-98 ZF-6
I have been running Lingenfelter headers now for a couple of years and have never been able to get them to seal worth a darn. Currently installing an Innovate wideband kit so I ripped the headers off in an attempt to try and reseal them (for accuracy) and noticed that the pipes stick through the flange about a 1/16 of an inch. Was wondering if anyone elses pipes looked like this or they skipped a step at the factory on mine. I would like to have them milled to a true surface before putting them back on. Just wondering if mine had a unique problem. Also, which gasket style works best with these pipes? I believe the 113 heads are D-ports but the pipes are somewhat rectangular shaped making it difficult to get one gasket style to work correctly. Help greatly appreciated as always!
Old Mar 12, 2006 | 05:28 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I'd have them trued and then get some copper or aluminum gaskets and I'd think your troubles would be over.
Old Mar 12, 2006 | 06:14 PM
L-9ate's Avatar
L-9ate
I ordered the Percy's dead soft aluminum d-ports, however, they say they are for 1992-1997, I know the 1997 is not right. Hopefully they will mate to my 113's alright.
Old Mar 12, 2006 | 07:16 PM
Corvette Kid
Well the LTx and 113 heads are both D port so it may be fine. But there are various D port sizes available too. You'll know when you get them if they'll work.
Old Mar 12, 2006 | 07:47 PM
L-9ate's Avatar
L-9ate
Crossing my fingers. Any idea what milling the flanges should cost?
Old Mar 12, 2006 | 09:51 PM
mikey whipreck's Avatar
mikey whipreck
i'm curious if other's headers are like that. Because I know mine stick out about 1/16" past the flange like you said your's do (I haven't installed my set yet).
Old Mar 12, 2006 | 11:44 PM
Edmond's Avatar
Edmond
Not necessarily. Even though Corvette's stopped using the LT1 after the '96's, the F-bodies were still a year behind so their '97's had LT1's.
Old Mar 13, 2006 | 01:07 AM
JCAIRE2's Avatar
JCAIRE2
I have Lingenfelter headers on my '88. I used percy's deadsoft aluminum for d-ports and have never had a leak. The primary tubes are welded to the flange on the engine side of the flange. If you mill them flat I think you will have problems with the integrity of the primary / flange connection.
Old Mar 13, 2006 | 06:35 AM
L-9ate's Avatar
L-9ate
I noticed that and was wondering if I could weld them back after they had been milled on the back side to prevent any leaks or weak points.
Old Mar 13, 2006 | 07:39 AM
Corvette Kid
Some headers are made as yours and some, such as my Stainless Works headers and my DRMs are made completely flat.
Old Mar 13, 2006 | 07:47 AM
neat's Avatar
neat
My Hooker headers are made as you describe. Copper gaskets, 10,000 miles, no leaks, 1 re-tightening after about 500 miles. Here's a good thread on the different gaskets:
http://forums.corvetteforum.com/show...10&forum_id=48
Good luck!
Old Mar 13, 2006 | 08:12 AM
MrNuke's Avatar
MrNuke
My LPE longtubes on my '85 are the same way. No leaks though as long as you do the correct way of tightening and re-tightening procedures for the first few weeks.
GB
Old Mar 13, 2006 | 01:09 PM
USAsOnlyWay's Avatar
USAsOnlyWay
LPEs here too. No leaks.
Al gaskets.
Old Mar 13, 2006 | 04:26 PM
L-9ate's Avatar
L-9ate
I did retighten mine a couple of times, but probably not as often as I should have when I first put them on. How many of you guys used copper RTV and if so on which side of the gasket or both?
Thanks for all the comments!
To Lingenfelter Headers
