MAF Sensor signal High
Old Mar 12, 2006 | 08:31 PM
bmwrollin's Avatar
bmwrollin
Default MAF Sensor signal High
Check engine soon light prompted use of scanner to read codes which indicated that I had a problem with the MAF Sensor. I took a drive and checked the operational data which shows a slightly high MAF signal under normal acceleration. Have been unable to determine the cause of this condition. Does anyone have any experience with this issue?
1988 Coupe
5.7
automatic
code 33
Condition is triggered when driving not during start-up or idle
Last edited by bmwrollin; Mar 12, 2006 at 08:57 PM. Reason: Additional Information
Old Mar 12, 2006 | 08:32 PM
vader86's Avatar
vader86
what is the year
what is the exact code
put the year and transmission type in your profile
Old Mar 12, 2006 | 09:03 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/corvette86/Code%2033.pdf
Old Mar 12, 2006 | 09:11 PM
bmwrollin's Avatar
bmwrollin
Default Thanks Agent 86
I have the book too. Got down to the part where it said to replace the ECM which I have already done but still get the same results.
Old Mar 12, 2006 | 10:48 PM
Morley's Avatar
Morley
Then you did replace the power and burnoff relays. correct?
Old Mar 13, 2006 | 11:38 AM
SunCr's Avatar
SunCr
Tough to crack when it's not a component. Make sure the Burnoff Relay isn't powered up. There might be a short to voltage on the signal wire or it's soaking up voltage from somewhere else. The only place that might come from would be the plug wires. Check them closely on the right side, particularly from the distributor to where they snake under the EGR tube. That's near the ECM harness and if one was leaking - worn insulation, the signal wire might pick it up and report a high voltage to the ECM.
Old Mar 13, 2006 | 12:46 PM
tequilaboy's Avatar
tequilaboy
In the chip there is a threshold of flow vs. rpm for setting this code, if you're modded enough you can exceed the threshold.
This can be edited or disabled easily in the chip. I think heads/cam/intake would put you close to the threshold. I didn't check to see your mods, if any.
MAF high diagnostic threshold looks like this (data from my 88):
rpm maf gm/sec
0 23
400 23
800 30
1200 48
1600 68
2000 89
2400 111
2800 141
3200 170
3600 200
4000 220
4400 236
4800 245
5200 247
5600 247
6000 247
6400 255
Old Mar 13, 2006 | 08:03 PM
bmwrollin's Avatar
bmwrollin
Default Relays
All tests indicated that the relays are functioning correctly and so I didn't replace them however my patience is about gone and ready to change anything and everything that may cause the problem. NOT!
The only mods are a performance chip and ACCEL fuel injectors(24lbs/hr). No other mods have been made so I doubt I have reached the threshold for air flow but I will compare with the numbers I recieved. The plug wires are not new but not very old either. I will inspect and make sure the clearence between them and any other wires. Thanks for the input guys.
Old Mar 13, 2006 | 09:02 PM
vader86's Avatar
vader86
Id replace the relays and then go back to the original chip.
Old Mar 13, 2006 | 09:09 PM
goldeneye_vet's Avatar
goldeneye_vet
This is just a thought but after my fiasco and code 33 on my 85 I'd check the wires to the harness for your MAF sensor. Mine appeared perfectly fine however contact was not being made with the pins from the MAF sensor itself. Take a small screwdriver and push all of the pins closer together in the harness and try that. You have nothing to lose if you try it but maybe this will help. The others have good advise for you as well but this is something little to try and I wish I would have done it 2 weeks earlier as it would have saved me a boatload of frustration. Good luck!
Old Mar 15, 2006 | 12:51 AM
John Pantera's Avatar
John Pantera
Default Dumb guy question
Would cleaning the thing help?
Old Mar 15, 2006 | 02:32 AM
Morley's Avatar
Morley
Start by checking the wiring to the fuel pump relay, look for bare wires near the socket. then move on to replacing the relays. I had a code 33 that would come and go, even while driving it would disappear and turn off the ck eng light. Checked the power relay and it functioned as advertised, but aparently the constant current going through it after being on for a while made it satrt to screw up.
Old Mar 15, 2006 | 11:48 AM
GlennS87's Avatar
GlennS87
I went through this when I tried one of the thin film MAF's (Wells SU-145). It would periodically throw a code. granted I'm highly modified but when I put my Bosch gutted sensor back on the problem went away.
To MAF Sensor signal High
