New Exhaust setup
Old Mar 14, 2006 | 02:28 AM
InsiGnia's Avatar
InsiGnia
Default New Exhaust setup
OK, first off, I just wanna say I'm pretty new to this stuff, and have a 91 coupe. But I have been looking around the forums and decided that I want to replace my headers with TPiS coated headers and a Corsa Cat-Back exhaust from madvet.com. (http://www.madvet.com/shop?frame=3.36.6986)
I just want to know if there is anything else I should do to my exhaust, since it is basically stock, save for the K&N air intake that came with it when I bought it. Should I buy the Catalytic Converter from TPiS, and should I replace the Y-Pipe as well? Thanks in advance.
Old Mar 14, 2006 | 02:47 AM
Phantom90's Avatar
Phantom90
I just got my Borla Stinger Cat-Back delivery today, you will not be disappointed
Hi Flow cats will be the next thing I put on. I am at a stand still concerning a mod air intake system, because I read negative things about certain air induction mods
Sooner or later I will just have to decide on one of them and go with it regardless.
New headers wouldnt hurt
Old Mar 14, 2006 | 03:44 AM
Demonic85's Avatar
Demonic85
I have a Magnaflow catback, high flow converter, and with all the hangers, misc. parts = less than $600. Thats modifying it to fit an '85. I like Corsa but its too expensive.
Old Mar 14, 2006 | 09:50 AM
Square's Avatar
Square
I have TPIS headers, and the Ramdom Tech High Flow cat they sell on my 86'.
I made a photo doc of the install detailing all the steps and issues I found. You can check it out here if you are interested:
header install photo doc
Old Mar 14, 2006 | 10:08 AM
jordis's Avatar
jordis
i know corsa is more reserved sound-wise. but does that system have a good powerful sound to it? like just different than other systems? or does it make your vette sound less impressive at start up than say a borla or flowmaster system.
just curious, im still tryin to figure out what i want to replace my lt1 tip, no muffler setup.
CJ
Old Mar 14, 2006 | 10:59 AM
mseven's Avatar
mseven
If you are installing headers I would do Y pipe, converter and back.
Old Mar 14, 2006 | 01:47 PM
DINO's Avatar
DINO
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
I went to Cruise-In V with Vetteweiser
I also have the TPIS set up with the Random Tech high flow cats ...nice mod .
Old Mar 14, 2006 | 07:57 PM
patsfan's Avatar
patsfan
From: Swanton VT 2000 Navy Blue Mettalic M6 / 1991 Auto - Steel Blue 68,500 R.I.P
Old Mar 14, 2006 | 09:56 PM
InsiGnia's Avatar
InsiGnia
Thanks for all the responses. Can anyone recommend a good Y-pipe that will fit the TPiS headers?
Old Mar 19, 2006 | 01:42 AM
InsiGnia's Avatar
InsiGnia
Anyone?
Old Mar 19, 2006 | 10:19 AM
tjwong's Avatar
tjwong
If I were you I would just install the TPIS headers and get a Corsa system for a 92 and up LTx car. Then you will have true dual exhaust. All you need to do this is to buy the LTx exhaust hangers for the system. You need one at the rear of the transmission and a left and a right rear hanger. Then you need two L brackets one at each muffler, which you may already have. The LTx system will just bolt right in, if you want CATs you can install a set of Dynatech Headers bullet cats that will slip right onto the TPIS slip on collectors. Then you need to reduce down to 2.5" to mate to the Corsa system. Any competent exhaust shop can make the connection for you.
Old Mar 19, 2006 | 02:47 PM
blown87's Avatar
blown87
GA Events Coordinator
To New Exhaust setup
