Convertible Hardtop Problems
Old Mar 14, 2006 | 11:27 AM
slatton79's Avatar
slatton79
2nd Gear
Default Convertible Hardtop Problems
Front captive bolt (a T-30) which holds the hardtop on the 'vert is stripped with the hardtop in place, how do I remove this captive bolt and replace????
Scott
Old Mar 14, 2006 | 11:51 AM
Caboboy's Avatar
Caboboy
Oh man, this is a tuff one
The only thing I can think of is to access the torx bolts that retain the mount on the top itself if you can get to them (I think there's three in a triangular pattern)............ otherwise you'll need to get to the head of the bolt that's stripped and pull it as you turn it out. This will involve trashing the upper trim piece, but this isn't too bad a hit. That header bracket is toast as well because that bolt is captive in there, so it shouldn't be too bad from that point with vise grips or whatever......you may even have to tack a steel rod on it to be able to pull it out. Like I said though, that header bracket will need replacing anyway
I've always wondered why the top doesn't attach front and rear the way the soft top does..........maybe that's too easy
Good luck Bud
Old Mar 14, 2006 | 03:49 PM
jerkyboy's Avatar
jerkyboy
Kind of the redneck way but if they are stripped bad enough, try the next size up in torx head and tap it into the bolt head with a hammer. It might seat itself enough to loosen. Good luck with it.
Old Mar 14, 2006 | 11:54 PM
Insane1's Avatar
Insane1
You didn't say wether it was the threads or the torx itself that was stripped. If it is the head/torx then maybe you could drill a hole in the end of the bolt and use an easyout on it?
Old Mar 15, 2006 | 07:59 PM
slatton79's Avatar
slatton79
2nd Gear
Default Bad Corvette week
It is the torx head itself that is stripped not the threads, seems the threads are fine.
Also, had a d@Mn ford back into me today, driver rear quarter, bumper and driver rear wheel damaged, I could have spit nails around lunch today. So I guess I'll let the body shop figure the stripped torx head out...
Old Mar 15, 2006 | 08:06 PM
87vette's Avatar
87vette
I stripped the torx head myself under the AC compressor and had no choice but to dremel the head off.
Old Mar 15, 2006 | 09:20 PM
c4cruiser's Avatar
c4cruiser
The bolts are T40's (same size as the B-pillar bracket bolts) but if the socket recess in the bolt is rounded off, you might try tapping an Easy-Out into the socket to see if you can get the corners of it to grab.
The windshield header bolts are not suppose to be very tight (11-17 ft-lbs) so if you can get something to wedge into the socket, the bolt should easiny turn out.
Once the top is off, the encapsulated bolt is not difficult to remove. Finding another one to replace it may be a different story.
To Convertible Hardtop Problems
