Best way to change out fuel injectors
Old 03-14-2006, 02:00 PM
BIG K
BIG K's Avatar
Default Best way to change out fuel injectors
I had my '89 (L98) was diagnosted and there are 2 bad and 2 marginal injectors. So, I'm going to replace all 4. The shop folks said that everything on top (runners, plunum, fuel rails) needs to be removed first. Do they?
What's the best way to go about this?
Thanks!
Old 03-14-2006, 02:08 PM
hippy
hippy's Avatar
Take the bolts out and remove the plenum, runners and rail in that order. I guess that's the best way to do it.
As long as you are in there buy a set of 8 and do them all.
Old 03-14-2006, 02:22 PM
RRT vette
RRT vette's Avatar
Just did this on my 86e. Take all the connectors loose, unbolt the Plentium and runners (throttle body can stay on just take off throttle lines). Then there is the fuel rail with 4 bolts holding it in. Also lossen the brake booster line on the back. You will see other little things once you get in there. Replace all runner gaskets with new ones. I strongly suggest replacing all 8 while your there, good bit of work for another one to go bad. JMO
Old 03-14-2006, 02:26 PM
Square
Square's Avatar
I agree with the others that you should replace all 8 if you are going to pull the rail.
If you want to see what you are in for, here is my photo doc of intake swap. You can see what you need to do to get the fuel rail out.
intake swap photo doc
I had my injectors serviced by Cruzin' Performance. If you can live without the car for a couple of weeks it is cheaper than buying a new set and they seem to work just fine.
Old 03-14-2006, 03:21 PM
85blkrose
85blkrose's Avatar
just got a new set of 24# accell injectors from jegs. change all 8 while your there. whywould you want to go through the hassel more than once!
Old 03-14-2006, 03:32 PM
Putter
Putter's Avatar
I strongly suggest to replace all 8 injectors. I bought 8 new ones from 5 0 Motorsports. It was less expensive than having my rebuilt (at the time). The injectors were guaranteed for 15,000 miles. I have only put about 1500 miles on my car since the replacement, but they work very well. The injectors, usually come from new Cobra Mustangs, but are taken out when Motorsports cranks up the power. Taking the plenum, runners, and various pieces is time consuming, but not very difficult. I even went ahead and pulled the intake manifold off so I could fix the oil leak( even though very minor) at the back of the manifold. Just make sure you label all of the pieces and correctly torque the bolts. I bought a Haynes repair manual. As I said, it is a little time consuming, but it is satisfying to know that the repair shop wanted $1300.00 to do the work. That money saved is going into my new cam, springs, and rockers!
Old 03-14-2006, 04:34 PM
RRT vette
RRT vette's Avatar
Old 03-14-2006, 05:07 PM
vinnies87
vinnies87's Avatar
St. Jude '03-'04-'05-'06-'07
Just to add to the listing: Make sure you remove neg cable, and depressurize the fuel line before removing the gas lines and injector rails.
Also, get some small bags and label all your bolts, or another trick is to take a pizza box and draw the part (both sides) and mark the holes then put the bolts in the holes on the pic, helps in reinstall.
Take alot of pic, worth a hundred words.
Old 03-14-2006, 05:34 PM
PAINTER MAN
PAINTER MAN's Avatar
All the advise above sounds right on the mark to me. I have done it on my 86.
Old 03-14-2006, 08:53 PM
bmalec
bmalec's Avatar
You can do the injectors without pulling the runners, that's what I did on my '89. Trick is to pull the plenum, then disassemble the fuel rail in place.
Sam Lam on the forum has a Word doc with some good tips on disassembling the rail with the runners still in place.
Good luck!
Ben
Old 03-15-2006, 09:39 AM
BIG K
BIG K's Avatar
Thanks for the responces. I would replace all 8, however I'm on a time crunch. I've have to wait a week for "overnight" shipping.
Do you think the best way to get the word doc is to IM Sam Lam?
Old 03-17-2006, 12:51 AM
Movnviolation
Movnviolation's Avatar
When I replaced the injectors in my 89, I checked the bolts on my intake manifold. Four were loose, and I saw signs of coolant on the rear of motor. I pulled the manifold and replaced the gaskets because I was there.
Not hard, just time consumming!
Old 03-17-2006, 01:14 AM
CentralCoaster
CentralCoaster's Avatar
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Where'd you order from?
Summit carries the Ford injectors and can get a set of 8 to your doorstep for about $240. These are much better than the multecs, if that's what you have on now.
Old 03-17-2006, 09:03 AM
AGENT 86
AGENT 86's Avatar
Try Five O Motorsports. I'll bet Bruce could have a set to you in a day.
Old 03-17-2006, 09:57 AM
BIG K
BIG K's Avatar
Parts Americia. $240 for all 8? $30.00 a piece! What a great price! I go mine for $48.00
To Best way to change out fuel injectors
Quick Reply: Best way to change out fuel injectors
