Finally
Old Mar 14, 2006 | 04:59 PM
fredk's Avatar
fredk
Default Finally
I just installed my rad last night. Heads, cam and headers finally done.
Does anyone suggest using water wetter in the coolant or just coolant.
Also what kind of a setup are you LT1 boys running after the headers, magnaflow will not fit.
Fred
Old Mar 14, 2006 | 06:56 PM
blown87's Avatar
blown87
GA Events Coordinator
I use water wetter in mine and it seems to help, even with the biggest "Griffin Radatior" i could put in there, it still runs hotter than i would like with the a/c on. When you push it a little hard.
Old Mar 14, 2006 | 07:00 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Fred
Any headers and any given exhaust system should be no problem. It's just a matter of making it hook together. Any exhaust shop worth it's salt should be able to handle it with no problem.
Old Mar 14, 2006 | 07:03 PM
bobmic93's Avatar
bobmic93
Fred
On my 93 I used the Exotic Muscle headers, two feet of extension pipe welded on to a X pipe then into a Corsa exhaust. Of coarse I cut off the resonator from the Corsa system. Sounds bad ***!!! Especially since my cam has a 110 LSA. Fred, you might consider heated O2 sensors.
Old Mar 14, 2006 | 07:50 PM
CFI-EFI's Avatar
CFI-EFI
I'd wait to see if it's needed. My experience is that it works, and works well, but why spend the money if you don't need it.
RACE ON!!!
Old Mar 14, 2006 | 08:01 PM
Corvette Kid
RACE ON!!!
Plus, you can't use antifreeze with this stuff, can you? I wouldn't want to give up the chemical protections that antifreeze provides in a street car. If it doesn't run cool enough to suit you, I'd solve the problem mechanically.
Old Mar 14, 2006 | 08:04 PM
95wht6spd's Avatar
95wht6spd
Yes, it's made to work with anti-freeze and/or water. I have used it for years and it helps, also lubricates your water pump.
Old Mar 14, 2006 | 08:16 PM
fredk's Avatar
fredk
Thanks guys, I have to run cats so I'm waiting for the new Magnaflow to come out. It should be out in a month, very short about 3-1/2" diameter and legal in 49 states so it should work up here in Canada. I asked Merle about heated o2's and he said I didn't need them.
Fred
To Finally
