Compressor just crapped out.
Old Aug 14, 2001 | 01:49 PM
KDuniverse's Avatar
KDuniverse
Default Compressor just crapped out.
I think its the clutch on the compressor, burnt out. I got half way down the street, and smelled the worst smell, and smoke everywhere. I went back home and opened the hood. I saw like black melted stuff near the compressor. I didn't smell it when the air was off, but as soon as I turned it on, there it was again...
Old Aug 14, 2001 | 08:53 PM
MY 95's Avatar
MY 95
CI 2-3-4-5-6-8-9 Veteran
St. Jude Donor '05-'06-'07-'08
Default Re: Compressor just crapped out. (KDuniverse)
ive never looked. does it look tough to change??
Old Aug 14, 2001 | 08:58 PM
SunCr's Avatar
SunCr
See if you can turn the pressure plate by hand. You can also put a 10mm socket on the bolt and see if it will turn. If it turns easily enough, then you only need a new clutch assembly. If it won't turn, then the compressor is seized and unfortunately, new ones ain't cheap (about $450 without the clutch at the Last Detail)!
Old Aug 15, 2001 | 02:30 PM
KDuniverse's Avatar
KDuniverse
Default Re: Compressor just crapped out. (SunCr)
Luckily I bought the car with a warrenty. Thank god. I've used it a lot, and it definately pays for itself.
Old Aug 16, 2001 | 02:43 PM
KDuniverse's Avatar
KDuniverse
Old Aug 16, 2001 | 02:45 PM
GlockLT4's Avatar
GlockLT4
I'd say you're right about the clutch.. but see if you can turn it manually like said earlier, that would check to be sure the whole compressor isn't gone.
Old Aug 16, 2001 | 02:50 PM
KDuniverse's Avatar
KDuniverse
Default Re: Compressor just crapped out. (Glock'94)
I just talked to my friend at the chevy place. It is definately the clutch, but he's going to put in a whole new compressor. Nice huh?
Old Aug 16, 2001 | 02:53 PM
shcuck's Avatar
shcuck
I just replaced the clutch and compresor about a month ago, and luckily I also purchased the car with the extended waranty and I only paid around $100. With out the waranty, it would have cost me around $1000.
Old Aug 22, 2001 | 11:04 PM
KDuniverse's Avatar
KDuniverse
Default Re: Compressor just crapped out. (shcuck)
just got the car back today. Brand new everything, for $50. :D
To Compressor just crapped out.
