center console pad
Old Aug 14, 2001 | 03:17 PM
Bigjo-NH's Avatar
Bigjo-NH
Default center console pad
What should I use to repair the cover on my center console.I have a 89 convert and the edges have come loose.
Old Aug 14, 2001 | 03:23 PM
TrplBlk01's Avatar
TrplBlk01
Default Re: center console pad (Bigjo-NH)
Mine are starting to also.... Keep us posted.. :smash:
Old Aug 14, 2001 | 06:29 PM
Wildride's Avatar
Wildride
Cruise-In II Veteran
I used Permatex "Weather Strip" Cement with Acco paper binder clips to clamp the edges down. 3M also makes a fine weather strip cement.
Also check out this: http://members.tripod.com/theviperpi...e/console.html
Old Aug 14, 2001 | 06:42 PM
89 Bob L's Avatar
89 Bob L
I used Elmers clear glue. It is a bonding glue for plastic and vinyl. I applied the glue around the edges, then used duct tape to hold the pad in place. I let it sit for 24 hours, then remover the tape. I was also going to use rubber bands as well, but noticed that where the bands were, they were causing indentations. I did this over one year ago and have not had any problems.
Old Aug 14, 2001 | 06:43 PM
Muffin's Avatar
Muffin
Default Re: center console pad (Wildride)
Went to a local canvas repair shop and got some HH-66 vinyl cement made by R-H Products. Cleaned the old cement off and reglued with this stuff. Has held for more than two years now. BTW I had a couple of bad rips in the console pad , mixed this stuff with a little black paint and used it to repair the rips. Not as good as a new pad but you have to look real close to find the rips.
Old Aug 14, 2001 | 06:47 PM
JTsTOY's Avatar
JTsTOY
Sergeant
Ditto- good glue and clamps.
Old Aug 14, 2001 | 07:00 PM
jwade91's Avatar
jwade91
I recently saw a black leather pad cover for the center console that Corvettes of Houston sells, I think either MidAm or Ecklers may have it too. Looked nice in the picture, comes with or without an embossed Corvette logo. It was described as a replacement cover, not something merely set or taped on top.
To center console pad
