Wheel size question
Old Mar 15, 2006 | 11:28 PM
95BlueBomber's Avatar
95BlueBomber
Default Wheel size question
I am wanting to purchase some wheels and slicks. I dont know where to start. What size will clear the brakes? How much backspace do I need for a 15x10? Will a 15x10 work on a c4? I found some at a swap meet but didnt know the exact sizes and no return policy there!
The Bomber
Old Mar 16, 2006 | 12:35 AM
rodj's Avatar
rodj
Previously posted by Mr Mojo.
Most of us are running 15 x 10's with a 7.5 backspace and a 5/16 spacer to clear the caliper. Grinding of the caliper will be required.
Old Mar 16, 2006 | 07:36 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
for the front I'm running 15x3.5 and with the standard brakes, they fit fine, but for '95-96 the J55 brakes were standard so youmayneed a spacer for the front to clear the caliper, I don't believe grinding of the front caliper is going to be enough. I never tried, but I knew a couple dudes that put the 15 x 3.5 up front and they needed spacers which by the way is not recommended. Don't forget the longer studs as well.
To Wheel size question
