Bypassing knock sensor? And.......reducing e/t's.
RACE ON!!!
I couldn't agree more. This is one of the biggest advantages of electronic engine mamagement. It protects the engine from itself.... and you.
The GN guys rely heavily on the stock knock sensor setup to keep their grenades from blowing up.
Spark knock on a boosted engine, my definition of living on the edge. Those pistons can "disassemble" themselves. You definitely lower cylinder pressure when a rod exits the block. My favorite is pieces of the block coming off with the pan. Nasty mess indeed.
I too love electronic spark timing.
dlmeyers 90 coupe zf6 3 speed shocks
I guess what I'm trying to say, is if you know you engine is up to snuff but think you could be suffering from false knock, how much of a benifit would this be to bypass the sensor, just for track use. Anyways just a thought.
If an engine, with the ESC disabled, is truly knocking it can destroy itself, if left unchecked. If an ESC receives false (or real) knock signals, the timing will be retarded. How much and to what degree the performance will be affected will depend in the severity of the signals (counts). Therefore, it is difficult to predict what the gains (if any) will come from disconnecting (or switching off) the knock sensor. In some cars, it will set a trouble code. If the ECM goes into the "limp home mode", performance may be further reduced.
Personally, my car was experiencing, verifiable false knock counts. Consequently, my knock sensor has been disconnected for about 5 years. Now, I detect knock the old fashioned way, I listen for it.
RACE ON!!!
Rich K
Most motors can live pretty long with occasional knock, however few will live long with the first onset of pre-igniton.
Knock is caused by pressure spikes in the combustion process caused by abnormal combustion, normal combustion happens in that the flame propoges from one side of the chamber to the other compressing the air/fuel ahead of it increasing pressure and temp in a "controlled" manner. When you get knock this flame propogatoin becomes unstable and the air/fuel ahead of the flame front starts to ignite under the pressure and heat spontaneously.
Conversely pre-ingition what people often mix up with knock or should I say pre-ignition effects are what people mistake for knock are devostating. Pre-ignition is caused by cross fire in the distributor or from a hot amber glowing off the carbon buildup in a motor that pre-ignites the charge in the cylinder as the piston is still traveling upward. This tries to drive the piston back down and you can imagine what that does when the others are sending it upwards,.
But knock is something that people greatly over-exaggerate. motors for YEARs ran without these knock sensors and with much WORSE fuel and heads/materials. Obviusly you should avoid knock if you do experiece is, as it can take its tole over time.
But if you know what your doing and do not try to get stupid with timing and lean on fuel you should be fine without the knock sensor. I say this as my finding are once you modify the motor you effectily change the frequency in which the motor's knock would occure anyways which detunes the knock sensors ability to pick up knock.
use your judgement, but also bone up on the causes and difference between knock and pre-ignition. Pre-ingition can kill the best running/tuned motor in a matter of a fraction of a second, if say you get distributor scatter and that spark jumps to the wrong post in the distributor. If you wanna see what it can do, I can send you a picture of my 1500 dollar billet crower rod!
As an aside, higher octane gasolines burn more slowly, and inhibit or retard the combustion initiated by the heat, alone.
RACE ON!!!
John
