hydraulic brake boost?
Old Mar 17, 2006 | 09:56 AM
PMD's Avatar
PMD
4th Gear
Default hydraulic brake boost?
I came here looking for some information/experience that some of you may have to offer.
While looking for the way to keep the master cylinder in the stock location on a retro-rod ('55 210 post coupe) and still clear the valve covers from a tall deck rat (572 crate), I ran into some pictures of a big block with big valve covers in a C4 or C5 with hyrda-boost. I can't find the site anymore, and I need to order some stuff pretty much right away. Anyone here know who the supplier(s) might be?
Another question: since we will be running 4 wheel discs, the braking setup should not be unlike a C4 in both size and type. Any comments on how the whole thing (hydraboosted, that is) works?
Pat
Old Mar 17, 2006 | 10:02 AM
kalister1's Avatar
kalister1
Sorry I cannot help with your question, but I do know that Hydroboost is used on all diesel equiped vechicles. Maybe searching around for Chevy diesel trucks?
Old Mar 17, 2006 | 10:42 AM
C-4 Now's Avatar
C-4 Now
One of my Vette? magazines had a article on a change-over conversion for this a few years ago? Can't remember name of company or date of magazine but remember very positive review. Ran boost off ps pump like diesel and had really firm pedal which is in line with my experience with these systems. Grand national, Turbo Regals had a complicated form of this system. Sorry couldn't help more. l
Old Mar 17, 2006 | 11:55 AM
Slalom4me's Avatar
Slalom4me
HydraTech Braking Systems
IIRC - the principal contact is Paul. Very willing to answer questions.
If you ever lose the link, just google on 'hydroboost'
Old Mar 17, 2006 | 12:02 PM
cv67's Avatar
cv67
St. Jude Donor '05
Late model Chevy full size trucks use them I believe, may want to check that out.
Old Mar 17, 2006 | 12:06 PM
Slalom4me's Avatar
Slalom4me
As C-4 says, boost is generated by the power steering pump. There
is a reservoir on the booster and in the event of an outage, there are
two or three presses on the pedal remaining before braking reverts to
full manual mode.
The Hydroboost system first came to my attention when it was installed
on 1 ton GM trucks in the l-70's/e-80's. I was impressed by the power
and the feel it generated.
Hydratech offers a system for the C4 but due to possibilities of pump
noise entering the cabin, they assign it an 'R' or race designation. The
design of the C4 pump appears to be the culprit and the issue does not
apply to older cars with the earlier p/s pump. Several C3 members
appear to be using the Hydroboost - it is a particular benefit for cars
with cams that don't generate enough vacuum to produce satisfactory
braking with conventional boosters.
Old Mar 17, 2006 | 12:13 PM
Slalom4me's Avatar
Slalom4me
Here's what one for a C4 looks like
Old Mar 17, 2006 | 09:40 PM
PMD's Avatar
PMD
4th Gear
Wow. Thanks for the excellent response.
I have driven hyrda-boost systems on 5.7 and 6.2 diesels, so I had a fair bit of confidence. Wasn't sure if the hardware was still available new and/or had been updated. However, getting such a solid response from gassers with 4 wheels discs is more than a little reassuring.
Slalom: Yes, it WAS Hydra-Tech that I saw. Couldn't remember the name and didn't book-mark the site (what an IDIOT!). Checked out their website, and I will be all over Paul on Monday morning.
Thanks again.
Old Mar 17, 2006 | 11:44 PM
Slalom4me's Avatar
Slalom4me
Let me know if you need measurements or different photos.
Old Mar 18, 2006 | 12:01 AM
Slalom4me's Avatar
Slalom4me
Incidently, if you have sufficent vacuum for a conventional
booster, I believe Master Power Brakes has specialty items
that might be worth checking out.
I remember seeing a small diameter, dual diaphram unit that
IIRC was targeted at BBC's with tall valve covers. Might
work also with tall deck. The dual-D cannisters pushed the
master cylinder out farther forward from the firewall but I
don't think space in that plane is a problem on a Tri-Five.
Found more information in MPB's catalog. On pages 5:
"SPECIAL BRACKET LIFTS BOOSTER UP TO CLEAR TALL VALVE
COVERS ON BIG BLOCKS AND LS1 COIL PACKS
Elsewhere on that page or the ones that follow, it mentions that
both 8" and 9" diaphram units are available.
HTH
Old Mar 18, 2006 | 09:04 AM
96CERon's Avatar
96CERon
Default You might find this one interesting
http://www.turbols6.com/gallery/view...album08&id=aam
Old Mar 18, 2006 | 09:09 PM
PMD's Avatar
PMD
4th Gear
HTH:
Should have power to the hoist on Monday, and will position the body over the chasis/engine for the first time early in the week. Then we will know how much room there is. If it is really tight, I will bother you for some numbers.
We do have a PS pump (AM chasis/Must rack....yeah, I know a FORD part on a Chivvy!! I won't mention the 9") and we probably won't have enough vacuum (something to do with 2000 CFM throttle body), otherwise the vac brake option you linked up would have been fine.
BTW: Do you solo with ASA? Don't know if I have seen you at the WCMA event in Saskatoon (only had a few Corvettes ever). I would have been the guy with daughters running weird Honda-powered karts (no class...literally and sometimes figuratively).
Ron:
Thanks for the pic. That should comfortably clear the v/c. Is that a GM unit or Hyra-Tech?
To hydraulic brake boost?
