Romulator Users
Old Mar 18, 2006 | 08:25 AM
MR.KIDD's Avatar
MR.KIDD
Default Romulator Users
Do any of you use the romulator for tuning?
How well does it work on the fly?
Old Mar 19, 2006 | 09:37 AM
tjwong's Avatar
tjwong
I use the romulator and it works fine, but when you make changes it doesn't perform a bumpless transfer. Sometimes a small change is OK, but larger changes like several cell changes will cause the engine to hiccup. I now use Craig Moates "Ostrich" which allows me to load any number of changes without the engine even noticing. Changes are immediate and bumpless. One great device, it has worked flawlessly since I have purchased it. The romulator works well in abouit 90% of situations. So far the Ostrich is 100%!
Old Mar 19, 2006 | 11:04 AM
MR.KIDD's Avatar
MR.KIDD
First thank you for responsing,I have a romulator that is on loan to me and was wondering if it would work with the 870 ecm, I see you perfer the Ostrich and I was wondering if the 870 would work with both?
Old Mar 19, 2006 | 06:45 PM
tjwong's Avatar
tjwong
Either device will work fine.
Old Mar 20, 2006 | 09:38 AM
GRX's Avatar
GRX
I have both. Have had problems with Romulator. The Ostrich works WAY GOOD on my 1985 with 870 ECM, simply awesome.
MR.KIDD's Avatar
MR.KIDD
Have you tuned any 870s with the romulator and if so what adapter did you use any pictures if possible. Thanks
To Romulator Users
