Will these fit?
Old Mar 19, 2006 | 02:42 AM
InsiGnia's Avatar
InsiGnia
Default Will these fit?
I want to replace my cylinder heads and camshafts, and was wondering if these will work well together with the TPiS longtube headers I am getting.
Heads:
http://store.summitracing.com/defaul...065+4294867028
Cams:
http://store.summitracing.com/defaul...=egnsearch.asp
I have a '91 L98. Thanks.
Old Mar 19, 2006 | 09:11 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The heads, yes, the cam, no. That is a solid flat tappet cam. You need to look for a hyd. roller cam. As for the heads, ask some questions as it seems that some headers are fussy on angle plug and straight plug heads.
JackDidley's Avatar
JackDidley
That cam will not work. Its a flat tappet cam, you need a roller. Ask a lot of questions and read a lot before you buy.
Old Mar 19, 2006 | 09:17 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
These are big investments, you certainly want to get it right the first time. Also consider your goals and the overall combination of parts needed to achieve them. Too much of this and too little of that can give you very disappointing results.
Old Mar 19, 2006 | 10:58 AM
InsiGnia's Avatar
InsiGnia
Thanks for the help guys, I really appreciate all the help. Since the first one won't work, how about this one? http://store.summitracing.com/defaul...=egnsearch.asp
Old Mar 19, 2006 | 11:45 AM
AGENT 86's Avatar
AGENT 86
Good choice
Old Mar 19, 2006 | 03:32 PM
vader86's Avatar
vader86
The cam you have picked is better suited to higher-revving engines, but it will work.
You will need a chip retuned for it.
To Will these fit?
