Something so easy
Old Mar 19, 2006 | 07:00 AM
Performance nut's Avatar
Performance nut
Default Something so easy
Is turning out to be not so easy. I am trying to remove the IAC and ran into a problem: I cant get a wrench or socket in to remove it. I tried removing the bird's nest of hoses on the passenger side of the TB to see if I could get a socket in there with no luck (might be the wrong size though). So, I tried a wrench, no room for an open or box ended wrench (keeps contacting the TB and/or bracket underneath). I have been able to loosen it with vice grips but they are leaving marks in the soft (brass?). So, I have a couple of questions:
First, what size is the fitting right next to the connector plug? I did a rough measurement and got 1 1/4"; however, my 1 1/4" socket doesnt seem to fit (not sure if it is too small or if there is some sort of interference). After doing a search, I found a link that said to use a 30-32mm spanner. After doing a conversion, 30mm is ~1.18" and 32mm is ~1.26". 1/100th of an inch shouldnt prevent a socket from sliding on, should it?
Second, does the IAC come out without having to remove either the TB or everything around the TB? All the articles/websites/manual simply say remove the IAC but make no mention of disconnecting anything (aside from the IAC electrical connection); however, two articles I read already have the TB removed. Using vice grips is not only marking up the IAC but it is tedious as hell since I only get a 1/16-1/8 of a turn before I have to reposition (and that mofraker has a lot of threads from all the pictures I have seen).
Old Mar 19, 2006 | 07:47 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Take the TB off and you should be able to remove it no problem with a variety of different tools - either wrench, socket or crecent wrench.
Old Mar 19, 2006 | 08:40 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Iv'e done it with TB on and TB off. TB off requires about 16 fewer swear words.
I too, used the vise grip (needle nose) method. Once !! Way too much crap in the way. Now that the TB coolant bypass is done, it makes TB removal a no brainer.
Old Mar 19, 2006 | 01:59 PM
kopbet89c4's Avatar
kopbet89c4
Yeah, who needs a TB circulating with coolany anyways? While you're at it, do a TB coolant bypass. I twisted my IAC off with Visegrips. T'was that easy...
Old Mar 19, 2006 | 09:11 PM
Performance nut
I figured it would be something like that. Thanks for the info guys.
BTW, the TB coolant bypass is not on my mod list but considering how easy it is, I might add it on since it doesnt get that cold here in California. If anything, it will clean up that birds nest next to my TB some.
To Something so easy
